999ecm
I upgraded my engine with Cyclone headers, Dart Iron Eagle 308 heads, Tyler Crockett cam and MSD ignition. I'd like to have my ECM reprogrammed to match the upgrades.
How much does it cost?
We can do the 999 ECM also. I will only re-map if done on the dyno. It's the most accurate way to tune. Tyler should be able to help you as well.
Ken,
As Mr HP said, the best way to do it is on the dyno. I can do it in the boat, but I would have to have it here. It can not be done with any confidence at all without doing it in the boat or on the dyno. If someone says they can do it by sending them just the computer, don't believe it. The only way that can be done is if someone has a program for the EXACT same upgrades.
Eddie
Eddie
