Aluminum Cylinder Heads & Salt Water >
Old 02-21-2008 | 07:05 PM
Default Aluminum Cylinder Heads & Salt Water
Is anybody using aluminum cylinder heads in salt water and if so are they holding up ? What manufacture are you using ? I am looking to replace heads on hp500 carb motors, I'm looking at Dart pro1 310's or AFR 305 or 315cnc.
Joby
formula 382 sr-1 is offline
Old 02-21-2008 | 08:29 PM
HotPursuit's Avatar
Im running Dart have run brodex both having no problems.
Tha t said I try to flush after every trip.I have heard canfield dont hold up as well.I have run aluminum for over 15 yrs and would never go back to steel.
HotPursuit is offline
Old 02-21-2008 | 08:37 PM
What Darts are you running ?
Old 02-21-2008 | 09:07 PM
Vinny P's Avatar
I hate the winter!!
I run AFR heads, but dont trust them to salt water. I run closed cooling to be sure I have no problems.
Vinny P is offline
Old 02-21-2008 | 09:10 PM
Are yours hard coated ?
Old 02-21-2008 | 10:09 PM
Vinny P's Avatar
I hate the winter!!
No, the heads are as they came from AFR. I have seen the salt eat through parts so quickly, I was amazed. It will not get me ever again.
Vinny P is offline
Old 02-22-2008 | 07:33 AM
BillR's Avatar
OSO Moderator
Joey Griffin put aluminum head on Jon B's motors. So far so good!
As long as you flush it religiously you'll be fine.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 02-23-2008 | 11:38 PM
I've run Brodix and Dart for years without any problems whatsoever....flush them after every use and you'll be fine.
thedonz is offline
Old 02-24-2008 | 12:33 AM
Registered User
Flush Flush Flush
Flush after every time you go out in salt water. Use some of them flushing chemicals that Yamaha sells for their outboards. Also some zincs would be nice.
29Firefox is offline
Old 02-24-2008 | 02:17 PM
sean stinson's Avatar
The Illustrious One
Veteran: Navy
Dart are very good just make sure you flush the salt out of the engines very thoroughly and use a product called salt away and when the foam bubbles come out of the tail pipes shut the motors down
Dying,....Is the day worth living for!!!!!!
sean stinson is offline
