vavle lifters >
vavle lifters
vavle lifters
Old 02-23-2008 | 12:17 PM
Ken N's Avatar
Arrow vavle lifters
I am rebuilding the top half of a 502 Gen. 6, engine would it be wise to reuse the stock GM roller lifters with a new roller cam.
Ken N is offline
Old 02-23-2008 | 03:44 PM
I would just for peace of mind. Bad things happen when they break. Real Bad. A friend had one fail and his bill was more than I have in my boat.
hdtvned is offline
Old 02-23-2008 | 04:00 PM
Depends on the hours and your technicall ability, you can clean and reuse them, if you know how to dissasemble and inspect them.
Is it worth saving $500 for piece of mind?
jeff1000man is offline
Old 02-23-2008 | 04:10 PM
Upgrade
The new cam will put more force on the rockers.
(I am guessing you are going to a bigger cam)
Also make sure your valve springs can handle a
higher lift cam without binding.
whatabout1 is offline
Old 02-23-2008 | 04:22 PM
Oh, I forgot. If you are using a high lift cam. I think they classify it at over.600, you have to use a special roller lifter in a Gen VI engine.
You should check with Merc, and find out the specifics before you make your desicion, and if you decide to purchase so you get the right one.
Check your springs for coil bind also.
Good luck with your project.
Old 02-23-2008 | 05:50 PM
Ken N -------------
NO, the hydraulic roller lifters by GM have poorly engineered blenders. There is no need for cleaning and re-assembly. Tests on the dyno (multiple) show that the GM lifter start to loose integrity at 3200 RPM. Use the CRANE 16535.
What cam are you intending to use? Do you have a MFG grind number?
tunertech is offline
Old 02-23-2008 | 08:42 PM
axapowell's Avatar
Where To
Originally Posted by tunertech
Ken N -------------
You will also have to use the original dog bones and spider from your motor with the Crane lifters. It is what I use as well.
Dave
axapowell is offline
Old 02-24-2008 | 12:24 PM
Ken N's Avatar
Arrow
Dave
what are the doge bones and spiders
Ken N is offline
Old 02-24-2008 | 12:37 PM
Default dog bones and spiders
a dog bone is a cast component that keeps the lifter from rotating much like the tie bars on typical roller lifters only they eliminate the physical connection between the lifters. There is one located between each par of lifters per cylinder.
The spider is a stamped spring steel device that bolts into the valley holding the dog bones in place.
They are very common in todays roller engines...
Ford started using them in the mid-eighties on the 5.0
When you take the intake off you will see.
Old 02-25-2008 | 07:12 PM
Stop by Wicked Marine in Brick and get some Morels from Jay. Fully rebuildable, made for marine applications.
cstraub is offline
BadDog
12
08-24-2006 08:00 PM
Perfectmix
8
03-23-2005 03:28 PM
shawn
8
03-31-2004 02:39 PM
Thunderstruck
4
03-10-2004 08:11 PM
Bo Knows
04-02-2002 09:20 AM
