TRS Drive Install
Old 02-23-2008 | 06:21 PM
justice's Avatar
Registered User
Default TRS Drive Install
Hey guys,replacing transom on Cigarette Mistress where it was rotted out.Still have all the original holes in fiberglass for my gimbals and k planes.What is the easiest way to make sure I drill my holes back at the right angle?
Attached Thumbnails TRS Drive Install-transom-replacement-006.jpg   TRS Drive Install-transom-replacement-016.jpg   TRS Drive Install-boat-ac-dogs-018.jpg
justice is offline
Old 02-24-2008 | 05:08 AM
cig1988's Avatar
When I installed my hydraullic steering I used a drill attachement. Not sure what its called but it turns the drill into a mini drill press. It attaches to the chuck of the drill with a shaft into another chuck with a plate on the business end with can adjust to different angles. Sears or a Lowes/Home Depot may have them. If you want I'll send you mine to borrow.
cig1988 is offline
Old 02-24-2008 | 05:33 AM
Registered User
get the tool
get your local merc shop to do it or loan you the tool
29Firefox is offline
Old 02-24-2008 | 05:57 AM
Audiofn's Avatar
Charter Member #232
You can have a machine shop drill you a hole in a piece of alluminum or steel. That will assure that you drill strait into the transom.
Jon
Put your best foot forward!
Audiofn is offline
Old 02-24-2008 | 09:10 AM
'05 Concept SF23
Bam or Cobra in South Fl should have a Merc drill fixture jig you could rent. I rented a 3/5 Speedmaster jig from Cobra when I did my Black Thunder.
f311fr1 is offline
Old 02-24-2008 | 01:16 PM
justice's Avatar
Registered User
Thanks guys,think I would be lost without this website!!
justice is offline
scarabfun
18
04-03-2008 07:55 PM
jhiguy377
Do It Yourself, Boating on a Budget
15
03-03-2008 08:11 PM
johnnyexcal
Excalibur
12
11-18-2007 02:19 PM
orjan
0
07-26-2005 02:32 AM
Poorsche
1
07-24-2004 07:51 AM
