02 Silverado starting problems
Old 02-25-2008 | 11:02 AM
Viper31's Avatar
Default 02 Silverado starting problems
My tow rig decided it did not want to start over the weekend. It is an 02' 3500 with 8.1 and Allison, about 30k miles. Drove it to my buddies house and it happened all the sudden. When you turn the key to start you get nothing. You can hear fuel pump run and starter relay in the fuse box click, but it seems the starter will not engage. Batt is good and I verified that there is voltage to the starter and solenoid. Anyone experience this problem before?
Viper31 is offline
Old 02-25-2008 | 11:10 AM
Wobble's Avatar
SORE MEMBER
Using a test light, do you get a signal to the small terminal on the starter solenoid when the key is turned to the crank position? If yes then it's the starter or starter solenoid, if not then it may be the keyswitch.
Wobble is offline
Old 02-25-2008 | 11:26 AM
Also is the security light is flashing after a starting attempt, then there is an issue with the theft deterant system.
Tow-N-One is offline
Old 02-25-2008 | 11:33 AM
Wobble's Avatar
SORE MEMBER
Good point and real common problem especially with after market alarms
Wobble is offline
Old 02-25-2008 | 12:50 PM
Viper31's Avatar
Wobble, Thanks - There is voltage to the solenoid when key is in crank postion.
Viper31 is offline
Old 02-28-2008 | 01:56 PM
Airpacker's Avatar
whack it with a hammer while holding it in crank. If it starts, do not shut it off until you get it to where you are going to do the starter.
Airpacker is offline
Old 02-29-2008 | 10:38 AM
Viper31's Avatar
Hammer whack was first thing I tried. I will pull starter off tomorrow and bench test it. I can't even remember the last time I had a starter failure. I know some will be give me $h!t but I have owned 4 Ford trucks in the last 15 years and none of them ever left me stranded. This is my first and maybe last Chevy truck.
Viper31 is offline
Old 02-29-2008 | 11:09 AM
My (first and last) Chevy truck, 2001 2500HD did the same thing 2 years ago. Replaced the starter and the problem stopped. Had more *stupid* kind of problems with this truck than all of my previous Fords, combined. Don't know if I got lucky with the Fords I had, or just really unlucky with this POS.
bob_t is offline
Old 02-29-2008 | 12:12 PM
Jassman's Avatar
can't be so...not a Chevy...they never brake and whoop dem Ford's butt all the time.
Jassman is offline
Old 03-03-2008 | 11:40 AM
Viper31's Avatar
Replaced the starter and now I'm back in action. I'm just glad this did not happen while trailering. Of course the transfer case defect will probably show up while I'm towing
Viper31 is offline
