Powerstroke 6.0 missing
Old 02-25-2008 | 09:33 PM
baja bailey's Avatar
Default Powerstroke 6.0 missing
About 2 days ago noticed truck had a surging jerking to it when driving at a steady speed (not towing). Now it has a miss at idle and when driving at steady speeds, seems ok when excellerating, and seems to be better after it warms up good. Today seemed to have a rough shaking idle to it, I think its getting worse,no check engine lights or anything coming on, any ideas 04 with 50,000 miles
baja bailey is offline
Old 02-26-2008 | 12:19 AM
handreasen's Avatar
Is'nt that the Powerstroke kicking in!
handreasen is offline
Old 02-26-2008 | 06:43 AM
bowtie's Avatar
Mine did the same thing, only at close to 150,000 miles. It was injectors, felt like a spark plug wire off on a gas engine. And it would come and go, Injectors are about 400.00 each after the core charge, and around 700.00 in labor per bank.
bowtie is offline
Old 02-26-2008 | 06:44 AM
Where is Spilman? He has over a million trouble free miles on 1/2 dozen Powerstrokes............ This thread is blasphemy!
Jupiter Sunsation is offline
Old 02-26-2008 | 07:03 AM
CigDaze's Avatar
It could be a bad injector. Symptoms are also consistent with a bad cam position sensor. Get the codes checked. It should tell you the problem. Should be a warranty fix with only 50k.
CigDaze is offline
Old 02-26-2008 | 09:58 AM
post your problem at www.thedieselstop.com
You should get an answer back quickly.
Fin
FINMAN is offline
Old 02-26-2008 | 10:27 AM
Registered User
Probably a stuck EGR. The injectors pretty much work or they don't. It's easy to clean and shut, then either search this forum or on dieselstop and look at defeating it. Depending on year ('03, some '04) you can remove a butterfly for additional benefit.
Being under warranty, you may want to have a new EGR installed, then definitely defeat it. Truck runs better and you eliminate the sticking problem.
Chris Sunkin is offline
Old 02-26-2008 | 10:29 AM
Wobble's Avatar
SORE MEMBER
ROFL
Wobble is offline
Old 02-26-2008 | 10:39 AM
Originally Posted by Wobble
ROFL
Ain't that the truth
FROGMAN524 is offline
Old 02-26-2008 | 11:59 AM
CigDaze's Avatar
Oh ya, forgot about that. Mine hasn't worked in a long time.
See here:
http://www.offshoreonly.com/forums/s...&highlight=egr
CigDaze is offline
