Putting a larger battery in a Waverunner?  Like a regular boat battery >
Old 02-26-2008 | 08:47 AM
BAJA WILL's Avatar
Registered User
Default Putting a larger battery in a Waverunner? Like a regular boat battery
Tired of always messing with a stupid little motorcycle battery in our waverunner. I was considering mounting a boat battery in it?? It is a 3 person and the battery is in the rear, plenty of room and we never have more than 2 people on it anyway.
So my question is will this hurt anything?? Their both 12 volt batteries one is just bigger and more amps??
WILL??
BAJA WILL is offline
Old 02-26-2008 | 09:11 AM
You may have to reinforce the mountings so it stays put. Being bulkier and heavier it will exert more force on landings.
Edward R. Cozzi is offline
Old 02-26-2008 | 09:14 AM
The main reason (beyond the light weight aspect) they use the smaller batteries is they are spill proof.
If you do hard turns, or should ever flip the ski over, you will be hosed with a standard battery. If you decide on a bigger one, make sure it's spill proof. Optima is probably the best choice...
VetteLT193 is offline
Old 02-26-2008 | 10:43 AM
We have 2 4-wheelers. One is a little older and has the small type battery. However, the other has a battery about twice the size of the lawnmower size battery. It is only about 1/2 the size of a car battery. Gel or absorbed glass (AG) is the way to go. If you go too large, the small engine battery charger on the waverunner may not be able to charge it.
THLWL is offline
Old 02-26-2008 | 10:55 AM
BAJA WILL's Avatar
Registered User
I was thinking of a small boat battery wich is about double the size of the battery in there.
Old 02-26-2008 | 11:13 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Are you having a draining/dead battery issue?
How about just putting in a battery cutoff switch?
Sydwayz is offline
Old 02-26-2008 | 12:15 PM
Knot 4 Me's Avatar
Switch to an AGM type battery and/or simply unscrew the positive lead when the ski is going to sit for any amount of time. It literally takes less than a minute to unhook the battery. I would not add a larger battery.
Knot 4 Me is offline
Old 02-26-2008 | 01:09 PM
You could go to the biggest (Harley) motorcycle battery. Not much bigger, but more cranking power. My bike can sit half the year and will start right up when I want to go.
Propster is offline
Old 02-26-2008 | 03:59 PM
BAJA WILL's Avatar
Registered User
cut off switch is not a bad idea, I had been unhooking it but the computer and crap has to be reset each time and its a hassle. Basically the computer has got to be draining it when it sits for more that 3 weeks.
Old 02-26-2008 | 08:12 PM
Yerp, a cut off switch is the way to go. The computers have just enough draw to kill a battery in a month or so. Install the switches and be done with the problems.
Darrell.
DMOORE is offline
waterboy222
05-17-2009 03:25 PM
tpmarine.com
New Products and Member Discounts
4
02-02-2006 09:50 AM
Mikey Likes It
18
01-27-2006 07:26 AM
luvlake
0
03-16-2004 04:55 PM
BAJA WILL
05-02-2003 05:26 PM
