572 Merlin typical WOT rpm range >
Old 02-28-2008 | 09:51 AM
Registered User
Default 572 Merlin typical WOT rpm range
Can anyone let me know what the typical WOT rpm range for a 572 Merlin engine is ?
excalibur27 is offline
Old 02-28-2008 | 11:28 AM
Block: World Merlin III cast iron, Merlin X aluminum
Crankshaft: Eagle 4340 forged crankshaft
Balancer: ProStreet internal
Connecting Rods: Eagle H-beam 4340 L-19 bolts
Pistons: Mahle coated/Manley
Piston Rings: Total Seal
Compression: 10 :1
Bore/Stroke: 540 c.i.d. = 4.500" x 4.250", 572 c.i.d. = 4.500" x 4.500"
Bearings: Clevite H-bearings
Camshaft: Hardcore solid lifter
Timing Chain: Hardcore double roller
Cylinder Heads: World Merlin (cast iron or aluminum)
Valves: Manley Stainless (2.300" intake, 1.880" exhaust)
Valve Springs: Hardcore
Retainers: Manley
Valve Locks: Manley
Valve Seals: Hardcore
Rocker Arm Studs: Hardcore
Pushrods: Hardcore 1pc., .080" wall
Pushrod Guide Plates: Hardcore
Rocker Arms: Scorpion aluminum rollers
Oil Pan: Moroso
Oil Pump: Melling
Assembly Components: Stainless hardware
Intake Manifold: Merlin-X single plane
Carburetor: Hardcore 1050 cfm (4500 type)
Distributor: MSD
Fuel: Pump gas
http://www.worldcastings.com/prods_pages/108052.htm
Max Rpm on the (#108055)572/675hp model is 6200rpm.
Back4More is offline
Old 02-28-2008 | 12:11 PM
It depends on how it was built to run. It could be anywhere from 5200-6000 depending on several things.
Griff is offline
Old 02-28-2008 | 02:29 PM
Registered User
I wouldn't want to be spinning Eagle cranks & rods at 6200 in a steady-state application. A few second burst running a car out on a 1/4 mile might be OK. I'd want to stay around 5600 with beer budget components. 62-6300 with premium components in a billet-cap block is reasonable.
The spec posted above is probably the Merlin crate motor, made for an automotive application.
Chris Sunkin is offline
Old 03-14-2008 | 10:28 PM
Hang Time 27's Avatar
I'm no expert, but it depends on the heads, cam and springs, which would help tell you where the power is - no use going any higher than needed - and that may only really be determined by actually running the motor in the boat at speed, trying different props etc..
Hang Time 27 is offline
Old 03-16-2008 | 08:58 AM
offshoredrillin's Avatar
Hey tommy,
the guy that built those engines for dave built everything safe. you should be fine for 52-5400. they were propped big for longevity with the trs setup. now with the Konrad's you have the durability. If i remember right Jeff told me that those engines are sweet, all the good stuff.
offshoredrillin is offline
mus90lx
05-18-2007 04:41 PM
LapseofReason
11-06-2006 12:40 PM
batty
5
01-13-2004 09:54 AM
mk3jlp
2
10-07-2002 08:04 AM
