Rebuild of 500 EFI
Old 03-04-2008 | 08:04 PM
Default Rebuild of 500 EFI
What is the best way to rebuild a 500EFI, pretty much getting all new internals, pistons, etc...... i want reliabilty much more than HP
Boomer35 is offline
Old 03-04-2008 | 08:41 PM
Send it over to Mark Boos @ Performance Marine in LA.
Bryan Rose is offline
Old 03-05-2008 | 08:23 AM
pkspx's Avatar
Call the best engine builder in the world.....tell him PK told you to call. He will sit down and talk about your options and help you out.
www.gellnerengineering.com
Dean Gellner 216.398.8500
Do a search on the board, trust me, you won't regret it.
pkspx is offline
Old 03-05-2008 | 08:58 AM
BAJA WILL's Avatar
Registered User
Tyler Crockett has some great rebuilds on these motors also.
WILL
BAJA WILL is offline
Old 03-05-2008 | 10:31 AM
Great guy as well!
Old 03-05-2008 | 12:49 PM
Big Time's Avatar
How many hrs on the engine...sure you need to rebuild the whole motor? Around 200 hrs (give or take) is a good time to rebuild the upper portion of the engine, but don't have to replace all the internals until later (500 or so hrs?). Might save you some cash just to do the upper half. As to what company you should use for new pistons, valves, etc., I will leave that to someone who has a little more experience.
Big Time is offline
Old 03-05-2008 | 09:15 PM
I recommend Dave Govados @ MDG Performance in MD. 410-956-5381. I believe he even has a couple in stock ready to go.
us1kw is offline
Old 03-05-2008 | 09:19 PM
just curious are you rebuilding the engine(s) in the fountain or the mystique?
heavyhauler is offline
Old 03-06-2008 | 05:04 AM
Linster's Avatar
Off the Radar
The rings are low tension GM- Use sealed power standard tension metric rings
No need to replace pistons unless defective
Check Rods
Hone block to ring spec
New rod & ring bearings
New Crane long Travel lifters
Check Deck & Heads for flat
New Cometic head gaskets
New Comp 929 Srings set 1880
Valve job
New 30 PSI oil bypass valve.
Inspect all parts
Let someone familar with marine engines do the job.
Linster is offline
Old 03-06-2008 | 06:08 AM
He already has a builder.
otis311 is offline
