5200 adhesive
Old 03-06-2008 | 07:36 AM
Default 5200 adhesive
I will be removing my trim tabs and wanted to save the hoses and indicator wires that go thrue the transom,the factory uses 5200 to seal then to the transom,is their anything I can you to soften the 5200 and removethe hoses and wires without breaking them??
boatnt is online now
Old 03-06-2008 | 07:40 AM
heat it up with a heat gun , or poke a piece of wire thru and cut your way around them . 5200 is awesome untill you want to take something off.. good luck
Old 03-06-2008 | 07:47 AM
bcfountain's Avatar
Registered User
Default 5200
i used combustion-chamber cleaner to soften the stuff.my gas fill was caulked w/5200 and it worked.
bcfountain is offline
Old 03-06-2008 | 08:14 AM
C_Spray's Avatar
Diamond Member #001
Use DeBond. It's designed for exactly that purpose. I've got some, and it works.
C_Spray is offline
Old 03-06-2008 | 12:47 PM
the debonder didn't work worth a chit on my stock tips.
it cant get at the 5200 to debond it unless it can get under it or between it and the surface.
By the time you accomplish that, half the work of removal is done!
that's the conclusion I was left with. Half a can is still around here somewhere.
Rippem is offline
Old 03-06-2008 | 12:56 PM
Good luck, On a large surface like behind trim tabs it is almost impossible to remove. It is likely to pull the gelcoat off the glass before the 5200 releases.
MOBILEMERCMAN is offline
Old 03-06-2008 | 01:16 PM
Registered User
old school
Chlorox straight up will soften up 5200. Trims tabs? the main thing is take it easy. Take a box knife and cut into the 5200 as deep as you can. Pour on some straight up Chlorox let it soak in over night. repeat soaking it in for a couple of days. Then get some wedges and drive em in just a little. Remember the key words are take it easy! Go too fast and like Mobilemercman said you'll lift the gel coat too. Anyways each day drive the wedges a little deeper cut what you can and spritz on some more Chlorox. Also the wedges that come with them slimjim kits work real good.
29Firefox is offline
Old 03-06-2008 | 06:02 PM
Donzilla's Avatar
Paint thinner works with a repeated process as it is oil based as is 5200 and paint thinner cuts it eventualy.Takes time and patience.
Donzilla is offline
Old 03-06-2008 | 06:41 PM
Hey boatnt are yous selling any of the old parts i may be looking for tab indicator sender...
PQCRAZY is offline
Old 03-07-2008 | 04:55 AM
cig1988's Avatar
Thats exactly what I used and it worked mint.
cig1988 is offline
