C. rotation, Inside out or outside in? >
Old 03-06-2008 | 01:58 PM
Default C. rotation, Inside out or outside in?
Any info or input on the different systems? Port outdrive rotating right ? or left? Starboard opposite.
Changing old Formula to C. rotation drives. Which side should I change??
PARADOX is offline
Old 03-06-2008 | 02:09 PM
Registered User
Inward
looking from the stern port clockwise stbd cntr clockwise
29Firefox is offline
Old 03-06-2008 | 02:23 PM
No, counter to what he said.
CanDo is offline
Old 03-06-2008 | 02:27 PM
That's not what I meant.. but thanks.
Should the props turn toward each other or away. What are the advantages or dis adv. ?
PARADOX is offline
Old 03-06-2008 | 02:30 PM
Ron P's Avatar
Enjoy the show
Step hulls seem to like the props spining inward. Conventional Vees seem to like the props spinning outward.
Spining out is more traditional and the boat will work better in reverse.
Do a search for Prop Rotation, lots of threads on this issue.
Ron P is offline
Old 03-06-2008 | 02:34 PM
Wahoo ATV's Avatar
Racer
We spin ours in and I believe that that is Fountain recommends. Tried them out and lost speed and handling. Now on my outboard cat we always ran them out.
Wahoo ATV is offline
Old 03-06-2008 | 03:18 PM
Default ?
old formula with #1 drives? change the port to c.r.
CanDo is offline
Old 03-06-2008 | 03:33 PM
Yep
MOBILEMERCMAN is offline
Old 03-06-2008 | 07:30 PM
THanks
Looks like port is going left. Majority rules.
PARADOX is offline
Old 03-07-2008 | 07:44 AM
Guess what, you should notice by now that everyone has a different opinion on this....thats caus it's slightly different on every boat....
Try it and see on yours.....the only REAL way to see what it does....even on the same boat make and model.....I have seen different performance issues
shoregasm is offline
