2004 Silverado Hitch Receiver Falling Off!! >
Old 03-08-2008 | 01:10 PM
Default 2004 Silverado Hitch Receiver Falling Off!!
Anyone ever had half of the mounting bolts and nuts just fall off over time???
SDFever is offline
Old 03-08-2008 | 02:03 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Are you towing your Fountain with the factory setup? Anything over 7500 lbs. requires a Weight Distributing hitch.
Hitches need to be regularly checked. Search "thisistank" 's posts about his Putnam just cracking in half. They are not bulletproof, and should be a regular part of your towing setup checks.
Sydwayz is offline
Old 03-09-2008 | 01:04 AM
No way. Got a little 27' with aluminum trailer. No weight at all - 5500LBS. Most of the mounting hardware was simply missing. Amazing.
SDFever is offline
Old 03-09-2008 | 03:39 AM
scottc's Avatar
Replace missing hardware with grade 8 fine thread bolts, waskers, lock washer and red locktight. And better after market hitch!!!!
scottc is offline
Old 03-09-2008 | 06:42 AM
jeff32's Avatar
2004... chances are someone took it off for some reason and forgot to put everything back on... or forgot to tork properly... or like I've seen once, a thief started to take it off, maybe he was seen and ran away! I've seen that for real...
jeff32 is offline
Old 03-10-2008 | 10:08 AM
Wobble's Avatar
SORE MEMBER
I put a torque wrench on my hitch bolts a couple of times a year after having one come loose back in the 80's. Every so often I find a bolt that is under tight
Wobble is offline
Old 03-10-2008 | 10:16 AM
BUIZILLA's Avatar
instigator
Don't be surprised if the holes in the frame are metric and the bolts are not metric.... IOW, the bolts can work loose..
BUIZILLA is offline
Old 03-10-2008 | 10:47 AM
tblrklakemo's Avatar
SeaRay Sundancer
They are not threaded holes. Just a bolt on the other end.
SDFever, those holes were probably never meant for a bolt. I know there are several holes on my silverado frame that just sit empty.
tblrklakemo is offline
Old 03-10-2008 | 11:02 AM
They probelly fell out when you brought that forklift home
Westcoast is offline
Old 03-10-2008 | 11:07 AM
Negative. All of the holes in the hitch frame itself are threaded and they are all the same thread. Got a new bolt kit coming from chevy. Most hardware on the street isn't above grade 8. Suprisingly, the oem bolts are 10. Thanks for all of the replies. Thinking that I was the only one this ever happened to was driving me crazy.
SDFever is offline
