Cam recommendation >
Cam recommendation
Cam recommendation
Old 03-10-2008 | 03:25 PM
Default Cam recommendation
Need a cam recomendation for a 454, .030 over. Was running a Reed .561/.576 lift on 104degree with 110 lobe separation. The engine had large oval port heads with the bigger valves, edelbrock RPM performer intake, Holley, Stainless marine dry exhaust, roller rockers w/ solid lifters. Not roller lifters. Got some water in the engine and I'm rebuilding and changing to the large oval port heads with smaller valves(had them laying around), hydraulic lifters and I need an intake and cam recommendation.
CN24 is offline
Old 03-10-2008 | 04:38 PM
Check with RMBuilder ( Bob Madara ) he is at Marine Kinetics 585-654-8583.
formula 382 sr-1 is offline
Old 03-10-2008 | 04:58 PM
how did you get water into the engine? presure test your manafolds and test your pipes. i had that happen & found 1 pipe had a crack inside. plug the bottom & fill it with water over night to see if pipe holds. manafolds should hold 20 psi
scarabfun is offline
Old 03-10-2008 | 07:21 PM
Intake manifold leaked.
CN24 is offline
WETTE VETTE
8
06-18-2005 12:33 PM
paragon
26
06-10-2005 02:43 PM
Jnewton
Fountain
10
05-24-2005 02:12 PM
BadDog
34
02-18-2003 07:27 PM
ITLLFLI
36
12-05-2002 02:08 PM
