Stupid question but i cant find the anwser >
Old 03-12-2008 | 09:29 AM
nocigarette's Avatar
Default Stupid question but i cant find the anwser
On the oil relocater at block which line is out from the pump...The one closer to the block or the outside one......here is a pic to help understand.....
I am plumbing a new oil thermostate.....
Attached Thumbnails Stupid question but i cant find the anwser-magnum-017.jpg   Stupid question but i cant find the anwser-magnum-140.jpg
nocigarette is offline
Old 03-12-2008 | 09:37 AM
Wobble's Avatar
SORE MEMBER
The line that goes into the center of the oil filter pad would be the return.
When you have everything plumbed, prime the oil system using the proper tool and then you can crack a few lines to make sure everything is going the right way. The oil will always go from the outside of the filter to the center.
You should also be able to get good oil pressure doing this.
Wobble is offline
Old 03-12-2008 | 09:43 AM
PatriYacht's Avatar
If you use a filter with an anti drainback valve,if you plumb it backwards, no oil will move when you go to prime the oil system. Your drill will load instantly but there will be no oil pressure in the engine.
PatriYacht is offline
Old 03-12-2008 | 09:12 PM
Thunderstruck's Avatar
Oil goes "In the Inner" hole on the block. The way I remember it anyway.
Long time cult member.
Thunderstruck is offline
Old 03-12-2008 | 09:22 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Simple.
Just remember on the filter:
oil goes in the outside and out the inside.
US1 Fountain is offline
Old 03-13-2008 | 07:03 AM
Thanks guys
Old 03-13-2008 | 08:13 AM
from strips motor..
Attached Thumbnails Stupid question but i cant find the anwser-4-1-05-015.jpg
open87 is offline
Old 03-13-2008 | 10:47 AM
Why does my oil thermo have two ports for (return from cooler) i only have one cooler....Due i plug one off and if so which one.....
Attached Thumbnails Stupid question but i cant find the anwser-magnum-141.jpg
Old 03-13-2008 | 10:57 AM
Here is some pics i just took to better understand what i mean.....
the second pic shows the third outlet for cooler...I am thinking i just block it off but why would the unit have 3 ports for cooler...????
Attached Thumbnails Stupid question but i cant find the anwser-magnum-001.jpg   Stupid question but i cant find the anwser-magnum-002.jpg
Bryan Rose
8
03-01-2008 11:00 AM
tjtyler
Baja
1
08-19-2007 12:57 PM
ROADHOG
Sonic
9
07-07-2005 11:39 AM
JTB
03-28-2004 10:27 PM
riskybusiness
05-06-2003 10:32 AM
