couple questions for the guru's >
Old 03-16-2008 | 04:22 PM
ENFORCER24's Avatar
Default couple questions for the guru's
I'm neering the end switching out heads/intake/carb/exhaust on my motor and have a couple of questions
1: I have the engine at TDC and when i put the distributer back in the rotor is facing #8 , 1 piston off , i can adjust the distributer to make it face #1 but thats not the way it came out , i didnt mess with the cam , just the heads . its confusing me
2: i also switched to a stainless marine t-stat housing and cross over , on the original Merc housing theres a sensor , i assume its a temp sensor , but theres another one next to it that screws into the water port on the intake , this is of less importance , i'll just find out which gauge aint working when i finaly fire is up
3: and this is purely for looks , when going to an aftermarket exhaust , i've mapped out where my shift quadrent is gonna go , and my oil filer and lines , any advice for the ign module and the wiring plug in in front of the motor?
check it out , it looks pretty good , kinda out of place in my junkyard boat
thanks in advance for any help
ENFORCER24 is offline
Old 03-16-2008 | 04:33 PM
oil pump shaft could of moved a little.
no big deal.
5050 is offline
Old 03-16-2008 | 04:44 PM
ENFORCER24's Avatar
oh yea , one last question
with the removal of the circ pump , my PS and ALT belts are way to long now , i saw this coming , does anyone know part numbers of the belts i need to buy ?
Old 03-16-2008 | 05:12 PM
GPM
Your engine looks very nice. 1 I agree the oil pump drive rod moved when you removed the distributor. If it bothers you, pull the distributor and turn the drive rod back with a long screwdriver, and reinstall. 2. The second sensor is probably for the alarm system in the boat.
GPM is offline
Old 03-16-2008 | 05:51 PM
ENFORCER24's Avatar
thanks , it'll look better when i get some exhaust for it
dean51267
20
08-05-2006 08:07 AM
dean51267
Prop Talk
8
03-21-2006 06:43 PM
seanv
American Offshore
13
11-16-2005 05:02 PM
hpy540
1
05-02-2005 09:21 AM
tm29
4
09-19-2004 05:16 PM
