Tunnel Tabs On 28ft Cat
I am thinking about adding tunnel tabs to my 280 cat. Is there any advantage to having hydraulic vs fixed for a tunnel tab? What can be expected as far as faster planing time?
I would like to cut the plane time considerably to help save my XR drive. Any help appreciated.
JRider
JRider
But they will help you alot and especially if its a porpouisin mofo like the 33 Daytona
My boat has never had a hint of porposing. Just trying reduce the stress on my drives. I can afford the 800 bones but for fixed tabs it is still crazy. I can fab my own to the exact dimensions of my tunnels enjoy doing it for $200. I'll save the rest for a tank of gas.
first time a none tried and true tab comes loose and beats the crap out of the transom you will think $800.00 was a steal
Go with the dana Monster tab!
Love it on mine!
HUGE gain in planning time and I can cruise around at 25mph with the tab down.
One huge problem with fixed tabs is adjusting for water conditions. I had them on my old Jet and V-drive boats.
Turnbuckles are a b!atch to adjust hanging over the transom
I will look for a picture when back at home
Otherwise here it the Factory link
http://www.danamarineproducts.com/Pr...TOKEN=30962851
Love it on mine!
This Cat is trying to keep up with the Big Dogs
the 28 profile is a single engine cat, monster tab will not work,
JRIDER, if you run a fixed tab, will there be any effect on the boat when coming off plane and the rear of the boat sinks, will it drive the nose down? I would like to se what you are building, I would be interested in a set for my 28.
thanks
larry
thanks
larry
