Anyone had any experience with cutting down the skeg on your lowers? >
Old 03-20-2008 | 05:40 PM
jryan26's Avatar
Default Anyone had any experience with cutting down the skeg on your lowers?
Wondering if there is any speed to gain? I heard Donzi does this sometimes?
jryan26 is offline
Old 03-20-2008 | 05:56 PM
No speed , don't do it.
MOBILEMERCMAN is offline
Old 03-20-2008 | 06:14 PM
I cut the skegs down a couple inches, tapered and sharpened leading edge on these engines. Ran hull mounted water pick-ups. The tip of the nose cone was two inches above the bottom of the hull. At speed about the only thing IN the water were the skegs. Picked up 1-1.5 mph. That's running well over 100 mph in a 2000 lb rig and I was trying to squeak out each and every mph. Not worth the effort on anything heavier or slower.
Attached Thumbnails Anyone had any experience with cutting down the skeg on your lowers?-boatntrailer.jpg
4mulafastech is offline
Old 03-20-2008 | 06:18 PM
GLH's Avatar
GLH
Read on here somewhere relating to #6's that the benefit of modifying skegs (sweeping them back) only started above 120 mph
GLH is offline
Old 03-20-2008 | 07:35 PM
jryan26's Avatar
This would be on a 39 topgun.
jryan26 is offline
Old 03-21-2008 | 02:07 AM
When the XR Sportmaster first came out there were many threads about how they were running 2 - 3 MPH slower than the standard XR lowers. The racers said they were having success cutting the Sportmaster skegs down and getting that speed back.
Marginmn is offline
Old 03-21-2008 | 07:27 AM
I've done it and it's easy. All you need is a good solid rock below the surface Generally I notice significant speed loss until I get the prop fixed
In all seriousness though, you have to be running triple digits and a pretty high X to gain speed by doing this.
VetteLT193 is offline
Old 03-21-2008 | 08:45 AM
Shanghied Again's Avatar
Registered User
Or a good sandbar running over 80mph will do the trick turns a Bravo drive into a shorty..
Shanghied Again is offline
Old 03-21-2008 | 12:22 PM
no gain and loss of stability......big neg in my viewpoint
shoregasm is offline
Old 03-21-2008 | 02:17 PM
nocigarette's Avatar
good read....
http://www.offshoreonly.com/forums/s...ighlight=skegs
nocigarette is offline
