Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Enlarging existing through hull holes >
Old 03-20-2008 | 06:34 PM
Default Enlarging existing through hull holes
I'm considering replacing my fuel and water tank vents with flush style vents. Also might have to replace my original bilge and sink drain through hulls since I found a crack.
The drains might fit the existing holes but it looks like the vent pieces would require a larger opening. Anyone wanna take a stab at how I could tackle making the holes bigger?
handfulz28 is offline
Old 03-20-2008 | 06:37 PM
Drum sander or hole saw. cut something with a hole saw to match existing hole and bondo in place. Use pilot from filler plug to hole saw proper size.
MOBILEMERCMAN is offline
Old 03-20-2008 | 09:11 PM
Audiofn's Avatar
Charter Member #232
You can stack hole saws on one bit if you have the good ones. Use the one for the size that you need and put that on first. Then put the smaller one on the inside of that one.
Jon
Put your best foot forward!
Audiofn is offline
Old 03-21-2008 | 01:39 AM
1CE
both excellent ideas
1CE is offline
Old 03-21-2008 | 06:05 AM
East Coast B's Avatar
I agree.... two hole saw setup.....
Drum sander bit on rotary tool will work fine also if you only have to increase the size of the opening by a small amount...
If you cutting through any wood, be sure to epoxy coat any exposed wood before closing up the job...
East Coast B is offline
Old 03-21-2008 | 06:18 AM
spazboz's Avatar
Find a rifle with the right caliber that will generate the correct size hole you need. Pull the trigger and POOF! Instant gratification, no regrets. Use the scope to accurately place the hole.
Otherwise, the stuff they said works good too...
spazboz is offline
Old 03-21-2008 | 11:04 AM
Thanks spaz, I don't think Formula would approve that 'caliber' of modification.
Jim, Jon, et al...much abliged for the good ideas. I thought about the two hole saw deal and wasn't sure if it was just a crazy idea. Hadn't thought about bondoing a plug.
Thanks!
Old 03-21-2008 | 09:17 PM
glassdave's Avatar
Neno the mind boggler
Jon
got damn skippy thats a pretty good idea. i usually span a piece of wood across the back and use that to hold the center bit. i like your idea better.
(dont know why i've never heard that one )
08 OPA High Points Champion
glassdave is offline
Old 03-22-2008 | 07:58 AM
Audiofn's Avatar
Charter Member #232
You have to be carefull but it does work very well.
Audiofn is offline
Old 03-22-2008 | 11:46 AM
Ted G's Avatar
BTW, Jon's idea works really well if you can find a "deep" smaller saw and a "shallow or normal" bigger saw. The deep one slides right in way before the outside one touches, centers up perfectly.
www.cbpba.com
Ted G is offline
