I need a marine 110 outlet
I am trying to add another 110 ground fault outlet in my Hustler. Here is a picture of what I have.Says Red dot on it which looks to be made by Thomas & Betts
Any suggestions of were to get this one or something that will work the same.Thanks,Rob
http://www.tnb.com/ps/fulltilt/index.cgi?part=CCGV
Strip,
The Red Dot is actually just the GFCI (Ground Fault Circuit Interupter) weather proof cover. They sell them at any Lowes or Home Depot. You will need an old work "cut in" electrical box, a GFI 110v 15a or 20a recepticle and a white GFI recepticle cover.
It is essentially the same equipment you would use to add an outdoor outlet in your house.
Hope this helps
Tom
Hope this helps
Tom
Strip,
Hope this helps
Tom
Hope this helps
Tom
So its nothing special? The "old work "cut in" electrical box" is that like a receptacle box ,metal or plastic?
I did search thru West marine,didn't find anything, but I kinda don't what the actual name I'm looking for
Strip,
Hope this helps
Tom
Hope this helps
Tom
I would use plastic and change over the steel mounting screws for the wings over to stainless steel. Simple enough to do. Like he said just ask for an old work high voltage rough in box at Home Depot or Lowes or were ever. I would get a hospital grade plug if they have them. They hold the cords in better then a el cheeeeepo
Put your best foot forward!
