Is it possible to remove??? >
Old 03-25-2008 | 07:23 AM
Default Is it possible to remove???
I have been seeing a bunch of older boats with those tall wings on the back (like Miami Vice style)..... is it possible to remove those things? Do most of them just bolt on or are the 'glassd on as part of the boat? Have any of you ever removed one of these things.... if so how difficult was it?
niceguy is offline
Old 03-25-2008 | 07:30 AM
45sonic's Avatar
Yes it is possible to remove them. Unless it is built into the boat (then that is going to require cutting and reglassing and either paint or gelcoat). Most are bolted and 5200ed which can prove to be interesting to separate sometimes. Patience and some prying help. Then all else fails do as I do get a BIG hammer
45sonic is offline
Old 03-25-2008 | 07:32 AM
GLH's Avatar
GLH
This and a good glass guy....
GLH is offline
Old 03-25-2008 | 07:46 AM
Knot 4 Me's Avatar
LOL! That is exactly what I was thinking. A good sawsall will take it right off!
Knot 4 Me is offline
Old 03-25-2008 | 07:57 AM
Almost all are bolted
CLIMAX is offline
Old 03-25-2008 | 08:34 AM
bluellama's Avatar
Or just put it on the trailer and drive through here......
bluellama is offline
Old 03-25-2008 | 09:09 AM
AIR TIME's Avatar
or once the bolts are off use piano wire with gloves works.
AIR TIME is offline
Old 03-25-2008 | 09:22 AM
Awesome. I was hoping for bolts. I've actually used a variation of the piano wire for removing badges and stuff from cars/motorcycles. Works very well.
niceguy is offline
Old 03-25-2008 | 09:29 AM
Fountain38SC's Avatar
Took mine off to paint it. 2 Bolts - no glue. Make sure you have help. I could lift it but getting it off the boat was another story.
Fountain38SC is offline
Old 03-25-2008 | 10:03 AM
jhiguy377's Avatar
I'd be very careful keeping it off permanently. High speed stability could be adversely affected. Midship laminar airflow enhancement is critical to compress trailing vortices from the windshield on these models. See Dodge Daytona Superbird aerodynamics for supporting evidence of this REALLY IMPORTANT phenomenon. Be careful out there - Jeff
jhiguy377 is offline
