Boat V Car Motor
Old 03-25-2008 | 08:21 PM
DMAX's Avatar
Question Boat V Car Motor
Can somebody tell me the diff. between lets say a 500 H.P. boat motor and a 500H.P.drag car motor. Thanks
DMAX is offline
Old 03-25-2008 | 08:52 PM
BY U BOY's Avatar
freeze plugs and tolerances are the 2 big ones
BY U BOY is offline
Old 03-25-2008 | 08:55 PM
monstaaa's Avatar
ones in a boat and ones in a drag car
monstaaa is offline
Old 03-25-2008 | 09:15 PM
seltzer's Avatar
Drag car 1/4 mile. Boat at least double.
seltzer is offline
Old 03-25-2008 | 09:19 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
One is made to go full throttle for 8-13 seconds.
One is made to go full throttle for 150-250 hours.
Sydwayz is offline
Old 03-25-2008 | 09:22 PM
One has torque on it for about four seconds then it shifts...torque again for another six seconds and its over.
The other has CONTINUOUS torque on it for many hours of pleasurable fun..................until it lets go on the bottom end
ve3lt is offline
Old 03-25-2008 | 09:31 PM
glassdave's Avatar
Neno the mind boggler
Torque and HP curves are very different. Generally i believe they come in much lower and there is more separation between the peaks in a marine engine.
08 OPA High Points Champion
glassdave is offline
Old 03-25-2008 | 10:04 PM
Strip Poker 388's Avatar
Rob
Thats what I would say,most drag big blocks in the 500 range I would say peek around 6500,unless it was a purpose built low rpm motor
Strip Poker 388 is offline
Old 03-26-2008 | 01:54 AM
A 500hp drag engine is simpler to build and can be done pretty easily with a small block. You can spin it to 7000rpms and don't have to worry about reversion caused by the cam or having it idle at 800rpms.
Griff is offline
Old 03-26-2008 | 04:19 PM
DMAX's Avatar
So in other words boat motors are built totaly different or just a little different ?
DMAX is offline
