500 bulldog
Yes. Below are the specs:
Mercury HP 500 Bulldog Specifications
Propshaft Horsepower: 470/350
Full Throttle RPM Range: 4800-5200
Displacement (CID/CC): 540/8.9
Bore (inches/mm): 4.44/112.7
Stroke (in.)/(mm): 4.375/111.1
Compression Ratio: 8.6:1
Cylinders: V-8
Fuel Requirements: 87 Posted Octane
BL
Cylinders: V-8
BL
Correct, great motor. Rated at 500 hp, but were a stronger running motor than the HP 500's. The 540 cubes pulled a lot harder on the bottom end and mid range.
