Do I need a high torque starter??? >
Old 03-30-2008 | 08:04 PM
BY U BOY's Avatar
Default Do I need a high torque starter???
My starter took a chit on me today Starter was only a year old. I'm running 10.7:1 compression and the starter i have now acts like my batts are dead when i crank it over. Will a high torque starter help??Or should i just have this one rebuilt?
BY U BOY is offline
Old 03-30-2008 | 08:35 PM
Tinkerer's Avatar
I have 509 CI at 10.5 to 1 and the stock starters do just fine. I do have 31 series batteries.
Get it rebuilt and make sure your batteries are good and cables are good.
Tinkerer is offline
Old 03-30-2008 | 08:58 PM
BY U BOY's Avatar
Batts and all cables were replaced 2 weeks ago and fully charged.I have a 27 and a 31.
BY U BOY is offline
Old 03-30-2008 | 10:56 PM
Go back and check the wires, especially any wires going to the starter, and other wires going to the engine. I had what I thought was a bad starter, but after replacing it, it still would not crank- it turned out to be wire that chaffed through on the engine block that was hidden in the back.
Also check out the ground straps on the engine.
dogturd21 is offline
Old 03-30-2008 | 11:08 PM
BY U BOY's Avatar
checked all that today. I tried to jump the started and nothing so i'm pretty sure its bad.
If it aint one thing its another
BY U BOY is offline
Old 03-31-2008 | 08:47 AM
Big Cliff
I was running the stock BBC starter on my blower motor and it had trouble turning it over. I switched to one of the new small gear reduction high tq starters and it turns it right over and fires on the first click. Worth the swap in my mind. Also ALOT smaller and lighter.
Old 03-31-2008 | 08:53 AM
If a starter is operated repeatedly under a low voltage,amperage condition it will fail quickly. Make sure that starter gets it's juice!
pachanga is offline
Old 03-31-2008 | 08:58 AM
Hey BIG Daddy just put a high torque , go on ebay and hit a buy it now for 65.00 brand new and enjoy the summer on the water ....
ROCK ON !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 03-31-2008 | 11:12 AM
Ebay Whore
jeff1000man is offline
Old 03-31-2008 | 11:14 AM
Check your timing again. THe fact that you thought it was wrong and you adjusted it, you might have over adjusted it and the engine has to much initial timing.
Anyway. I never knew that weed eater engines had electric start.
