28' scarab excel, 540 merlin 640hp prop help >
Old 03-31-2008 | 08:25 PM
Default 28' scarab excel, 540 merlin 640hp prop help
Hey guys. I have a 28' scarab excel with a 540" merlin that is putting out 640hp @5500rpm, and an XR drive. What do you think I should run with this set up? Any advice is appreciated. Also, what kind of speeds should I expect? Thanks, Matt
slinger7101 is offline
Old 04-02-2008 | 07:26 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
There are so many variables that it makes it tough to determine the top speed without a base line. If you have exact wet weight including all gear and fluids, I can get a very close guess. Try a 28-30 Bravo 1 propeller as a starting point.
[email protected]
bbladesprops is offline
Old 04-02-2008 | 07:55 PM
I had a customer with an identical setup. He ran a 28 bravo 4 blade. He was running high 70's.
TxHawk is offline
Old 04-02-2008 | 07:59 PM
Thank you for the reply guys. I will start with a 26p bravo I can get my hands on and use that as a starting point.
Old 04-04-2008 | 03:33 PM
Scarab28's Avatar
A 28 B1 is what you'll need - will get you in the mid 70's around 5400 RPM - been there
Scarab28 is offline
Old 04-04-2008 | 04:15 PM
Thanks Scarab28. How fast do you run, and how does it handle at those speeds?
Old 04-04-2008 | 08:48 PM
Scarab28's Avatar
Currently running M2 procharger on a 540, approx 800 Hp. Currently runs 80 GPS at 5k with a 32 B1. I just picked up a 30P B1 to see if I can get the RPM's up in the power range. I ran at 78 with the 28P B1, but it ran about 75 with the 28P on same setup but a 468 BBC. It begins to get squirly over 75 MPH. I hear going with a two inch shortie and extension box straightens the ride out.
Scarab28 is offline
Old 04-05-2008 | 06:31 AM
That sounds like a nice ride. Thanks for the info. Matt
darrenhagan
07-01-2007 05:36 PM
ferraristyle
08-14-2006 09:42 PM
JP
Scarab
3
02-11-2006 08:55 AM
homan
20
07-19-2003 11:19 AM
Keith
Scarab
2
04-22-2002 08:30 AM
