What are brand are you using?
Old 04-01-2008 | 10:06 PM
sleek1's Avatar
Default What are brand are you using?
for trailer tires? How many ply? Buying new tires for a 353 with an aluminum trailer/tri-axle. Hooked up weight is 11,400 with only 50 gallons of fuel. I can get a good price on Towmaster 8 ply are these good tires?
sleek1 is offline
Old 04-01-2008 | 10:32 PM
Registered User
Goodyear Marathon.
Never had an issue although others will tell you they have. Goodyear also makes a commercial tire- basically a tire for lowboy trailers. Big $$. I think they're 16 or 18 ply.
Towmaster is a Greenball brand. Not bad stuff.
Chris Sunkin is offline
Old 04-01-2008 | 11:31 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
You can't have too much tire. Go with the E-load rated tires. D-rated is OK, but E is perfect.
I run Firestone Trans Force LT E-load rated tires on my trailer.
Sydwayz is offline
Old 04-02-2008 | 05:06 AM
mama tryed's Avatar
What size rims do you have?
mama tryed is offline
Old 04-02-2008 | 07:52 AM
nomomoney's Avatar
I just put Carlisle 10 ply E rated on my trailer.I have 15 inch rims 225/75/15.I replaced the Goodyear marathons D rated.The Goodyears always looked like they were always low even when at correct pressure.I really like the Carlisle's.
nomomoney is offline
Old 04-02-2008 | 08:07 AM
rchevelle71's Avatar
Goodyear marathons on the new trailer.
rchevelle71 is offline
Old 04-02-2008 | 08:30 AM
myco uses goodyear at tracker. better to be over tired then under.
bgchuby01 is offline
Old 04-02-2008 | 08:45 AM
sleek1's Avatar
I'd have to double check. I have not taken posession of the boat yet but the tires are too worn so I want to replace them when I get the boat.
sleek1 is offline
Old 04-02-2008 | 08:58 AM
anybody with 16's needs to look at the Bridgestone R230/R250 or the Michelin commercial RIB and be done with it.
These are tires with all steel construction.
Virtually every other tire on the market spoken of or considered here is a polyester sidewall/carcass tire.
The Michelins run about 200 ea.
The B'stones about 160.
But what price confidence?
These two are seriously tough, long-wearing tires.
Rippem is offline
Old 04-02-2008 | 09:22 AM
obnoxus's Avatar
Charter Member #1171
Goodyear Marathons on smaller trailers.
I run Toyo's on the Outlaw trailer.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
