Gil Marine or Imco exhaust >
Old 04-04-2008 | 02:55 PM
Default Gil Marine or Imco exhaust
I have a chance to get a used set of each. Is one better than the other and what would be a fair price. They come with the risers.
This will be going on a 1998 7.4l
quadracr is offline
Old 04-04-2008 | 03:12 PM
I would get the Gils for the fact that they use a dry joint between the riser and manifold. Imcos have a wet joint.
Griff is offline
Old 04-04-2008 | 04:20 PM
I think I'll go with the Gills since after questioning the other pair wasn't IMCO's they were the Merc HP500 manifolds and risers.
quadracr is offline
Old 04-04-2008 | 04:24 PM
98itrwhite's Avatar
i thought hp500 manifolds were gil from the factory
98itrwhite is offline
Old 04-04-2008 | 04:54 PM
Registered User
The merc is a different casting and reportedly more leak-prone. The Gil is vulnerable to heat damage right in the exhaust pocket- if you lose an impeller and run them, they'll crack/melt there. A visual inspection is paramount, a pressure test is easily accomplished.
Gil makes wedges that allow for tailpipe fitment if they're the long-pipe style.
Chris Sunkin is offline
Old 04-04-2008 | 05:10 PM
Thanks guys for the input, but I'm about to show my inexperience. Chris when you says wedges, does that mean wedges that would go underneath the riser to change the angle? If thats the case, I don't think I'll have to worry as I am now using the stock exhaust which makes a sharp dowward angle and the back. I plan on installing 4" tips straight out the back.
quadracr is offline
Old 04-04-2008 | 05:14 PM
Registered User
Yes, those are what the wedges are for.
Remember the old carpenter's adage on those thru-hull holes...
"Measure twice, cut once"
Old 04-04-2008 | 05:16 PM
Elite Marine's Avatar
Gils
Elite Marine is offline
Old 04-04-2008 | 08:01 PM
Vinny P's Avatar
I hate the winter!!
I vote for Gils also. The dry joint is a big plus in my book.
Vinny P is offline
Old 04-04-2008 | 08:44 PM
gils
scarabfun is offline
