Best way to safeguard a trailer from theft.
Whats the best way to keep someone from takeing your trailer when not hooked to the truck. I thought of running a chain through the rim and to the frame. But if thay want it thay will get it. I just want to slow them down a bit till I kick the dogs loose and load a gun or two.
It's true...what one man creates another will destroy!
I like a boot device to a) provide a visual deterrent - which is arguably the most important thing and b) slow them down if they do decide to make a theft attempt.
A boot combined with a stout hitch lock work very well for anti-theft. Obviously, if equipment is left in remote areas for extended periods of time...the power tools are more likely to come out and play...
Problem with chains is that anybody can buy lock/chain cutters. A boot takes more effort and is easy on and easy to store and usually takes some time to defeat...
www.tirelock.com
Full disclosure out of respect for OSO members: I am not only a user, but also the owner of tireock. This is not a sales pitch - just an answer and opinion to question posed.
www.tirelock.com
The boot looks sweet!
Currently using the Master coupler lock, pin lock and chain through two wheels. Also think about when you're towing. I've heard horror stories on the road. Pull a fuse in the truck and I also use a heavy grade chain from truck to trailer. I figure the longer I could hold someone up the better chance I have.......
in hitting them with the tazer, duck taping them then.....
