F350 with air brakes
Old 04-06-2008 | 02:53 PM
kevinr's Avatar
Registered User
Default F350 with air brakes
Looking at a trailer for my TG ,but it has air brakes I pull with a 04' F350 , ever heard of installing air compressor on trailer or truck with electric brakes controller,,,, I sell trialer brake parts , So I know I can convert to hyd. but thinking about a F650 later with 5th wheel
kevinr is offline
Old 04-06-2008 | 03:23 PM
most trailers with an air system is air to the trailer where it is changed to hydraulic. I would suggest changing the trailer to electric over hydraulic. By the way, most 650 have hydraulic disc. the yellow knob on the dash is only for parking.
bgchuby01 is offline
Old 04-06-2008 | 03:25 PM
how old is the trailer you are looking at. most late model trailers do not use that setup anymore. If the trailer is true air including the trailer axels then you can;t float the boat since the salt will kill the s cam assembly of the brake system
Old 04-06-2008 | 03:58 PM
bgchuby,
How do you figure the salt will destroy the S cam? You run a trailer on salty roads for thousands of miles for many years with no harm? There is always salt spray up in there you can see the brake shoes frames covered in white salt from the water evaporating. The cam itself rides on nylon bushings, I would think air brakes would be the best to submerge?
Joe Gere
HabanaJoe is offline
Old 04-06-2008 | 04:21 PM
kevinr's Avatar
Registered User
its a myco and was custom set up for air
kevinr is offline
mcraymond3
2
05-05-2008 08:00 PM
BillR
15
10-17-2007 10:55 AM
cbeastwood
4
01-01-2007 08:27 PM
ShootinTheBreeze
6
06-21-2006 07:38 PM
skatermike24
04-25-2003 11:29 AM
