there is only one person on here with fuel pressure? >
Old 04-08-2008 | 05:09 AM
ak
Default there is only one person on here with fuel pressure?
i was wondering what you guys run for fuel pressure into your carbs,and what is the min and max.
ak is offline
Old 04-08-2008 | 06:46 AM
White Knuckles's Avatar
I run about 8 pounds on a mechanical pump.
White Knuckles is offline
Old 04-08-2008 | 07:48 AM
Thunderstruck's Avatar
5-7 psig, when wide open drops to 4 psig or less I replace the pump(s).
Long time cult member.
Thunderstruck is offline
Old 04-08-2008 | 09:23 AM
BY U BOY's Avatar
Between 6 and 8lbs Mechanical pump
BY U BOY is offline
Old 04-08-2008 | 09:39 AM
Big Cliff
On the blower motor about 8psi at idle with 6-7psi WFO. Electric pump.
Old 04-08-2008 | 09:42 AM
Wobble's Avatar
SORE MEMBER
Electric system with fuel log with built in bypass return 6psi idle or wot
Wobble is offline
Old 04-08-2008 | 10:10 AM
I run 7lbs on a electric fuel pump with an aeroquip bypass regulator. It runs 7 pounds all day long no matter what load and never moves the needle.
I have -8 an lines to the carb and a -10 supply and bypass line, easy set up and works great. I even run the fuel line thru the oil cooler ports that was supposed to be used for power steering cooling use.
VegasHallett is offline
Old 04-08-2008 | 10:13 AM
Between 5 - 7#... Mechanical pump
Back4More is offline
Old 04-08-2008 | 02:24 PM
9 psi mechanical with electrical back ups to 12 psi...581 blower moters
thedonz is offline
Old 04-08-2008 | 04:52 PM
I run blower motors with electric pumps feeding my Merc mechanical pumps. Run 6-8 psi depending on throttle.
Darrell.
DMOORE is offline
