Gaffrig Blowout!!
Old 04-08-2008 | 05:23 PM
CPPerformance's Avatar
Default Gaffrig Blowout!!
Okay folks, here is your opportunity to save big on some overstocked Gaffrig gauges. You will not find prices like this anywhere and there are only a limited supply so don't hesitate!
Please do not ask for a gauge that is not listed because I do not have it!! Any extra gauges that you might need can be replaced with our Autometer, Livorsi Marine, or Hardin Marine gauge lines only.
Got senders? All senders all sold seperately so let me know if you need them when ordering a gauge off the blowout list.
Let the games begin
All orders can be taken by phone, email or private message only and is based on a first come first serve according to the date and time of a request.
CPPerformance is offline
Old 04-08-2008 | 05:24 PM
Qty and Sell Price in RED
Part# - Qty - List $ - Sell $ - Description
4004 3 109.76 $41.00 3-3/8" Mech.Dry Speedo 80MPH, BLK
4020 3 373.17 $138.00 GPS Digl. Speedo Head, BLK
4024 1 373.17 $138.00 GPS Analog 120MPH Speedo, BLK
4026 1 170.73 $63.00 3-3/8" Mech. 100MPH Speedo KT, BLK
4028 1 170.73 $63.00 3-3/8" Mech. 120MPH Speedo KT, BLK
4038 4 170.73 $63.00 3-3/8" Mech. 60MPH Dry Speedo, BLK
4040 4 170.73 $63.00 3-3/8" Mech. 80MPH Speedo KT, BLK
4250 4 165.85 $62.00 3-3/8" Elec. 0-10000RPM Tach, BLK
4252 12 165.85 $62.00 3-3/8" Elec. 0-6000RPM Tach, BLK
4254 1 165.85 $62.00 3-3/8" Elec. 0-8000RPM Tach, BLK
4502 40 109.76 $41.00 3-3/8" Speedo White
4508 1 109.76 $41.00 3-3/8" MechDrySpeedo 120MPH, WHT
4525 3 819.25 $303.00 GPS WHT Analog KIT
4526 7 170.73 $63.00 3-3/8" Mech. 100MPH Speedo KT, WHT
4528 3 170.73 $63.00 3-3/8" Mech. 120MPH Speedo KT, WHT
4538 3 109.76 $41.00 3-3/8" Mech Dry Speedo KIT, WHT
4540 3 170.73 $63.00 3-3/8" Mech. 80MPH Speedo KT, WHT
4750 6 165.85 $62.00 3-3/8" Elec. 0-10000RPM Tach, WHT
4760 4 195.12 $72.00 8K Tach/Hour I/O, WHT
5001 1 217.07 $81.00 DGTL Sound Head W/Alarm, BLK
5002 1 41.34 $16.00 Electric Fuel Level, BLK
5004 2 46.95 $18.00 2" Elec. Fuel Press 0-100PSI, BLK
5006 3 46.95 $18.00 2" Elec. Fuel Press 0-15PSI, BLK
5008 3 46.95 $18.00 2" Elec. Fuel Press 0-60PSI, BLK
5020 3 107.93 $27.00 2" Elec. Oil Temp., BLK
5024 1 72.00 $36.00 Elec. Pyrometer 0-1600, BLK
5026 16 46.95 $18.00 2" Elec. Trim Meter Merc, BLK
5032 9 41.34 $16.00 2" Elec. Voltemeter, BLK 8-16V
5040 10 41.34 $16.00 2" Elec. Water Temp. BLK 100-240F
5050 2 85.37 $32.00 2" Elec. Fuel Press. BLK 0-60PSI
5504 5 46.95 $18.00 2" Elec. Fuel Press. WHT 0-100PSI
5508 4 46.95 $18.00 2" Elec. Fuel Press WHT 0-60PSI
5514 2 85.37 $32.00 2" Elec. Oil Press. WHT 0-100PSI
5518 1 85.37 $32.00 2" Elec. Oil Press. WHT 80PSI
5526 3 46.95 $18.00 2" Elec. Trim Meter Merc. WHT
5530 1 [B]20.00[B] $18.00
2" trans/temp Elec white
5532 8 41.34 $16.00 2" Elec. Voltmeter WHT 8-16V
5542 3 41.34 $16.00 2" Elec. Water Temp. WHT 100-280F
5550 2 85.37 $32.00 2" Elec. Fuel Press. WHT 60PSI
5552 2 85.37 $32.00 2" Elec. Trim Meter Merc. WHT
6018 1 66.34 $25.00 2" Mech. Vac. 0-30HG/0-30PSI BLK
6516 1 66.34 $25.00 WHT Vacuum Gauge
9100 1 48.78 $18.00 Fuel Press. Sender 0-100PSI
9110 3 19.51 $8.00 Oil Temperature Sender 1/2"
9124 1 19.51 $8.00 Water Temp. Sender 1/4"
9132 8 19.51 $8.00 High Water Temp. Sender 1/4"
9134 10 19.51 $8.00 High Water Temp. Sender 1/8"
9136 4 19.51 $8.00 High Water Temp. Sender 1/8:"
9138 5 109.76 $41.00 Fuel Level Gas 0-12" Tank
9140 6 112.2 $42.00 Fuel Level Gas 0-24" Tank
9251 16 436.59 $162.00 GPS Receiver, WHT
9256 1 15.25 $6.00 Brass Comp. Fittings
9300 30 9.15 $4.00 Toggle Switch Mom. On/Off
9400 30 8.54 $4.00 Rubber Boot BLK for Toggle Switch
9401 24 8.54 $4.00 Rubber Boot WHT for Toggle Switch
13005 1 75.52 $32.00 2-5/8" Voltmeter, WHT
9000-05 2 346.35 $128.00 Hydro Cool Powercoated, BLK
9000-08 1 346.35 $128.00 Hydro Cool Powercoat. Polish Alum.
Last edited by CPPerformance; 11-19-2008 at 07:29 PM. Reason: New List and pricing!
Old 04-09-2008 | 07:42 AM
rrentsch's Avatar
Registered User
Looking for a Gaffrig GPS anlog speedo to match these, Item 4522 or 4525, can you supply it with a sending unit ?
rrentsch is offline
Old 04-09-2008 | 03:05 PM
Yes I have either one of those gauges available, just let me know if you want 90MPH or 120MPH. The GPS receiver would be sold seperately for $210.99. Let me know.
Thanks,
Brad
Old 04-17-2008 | 08:34 AM
Sick Stinger's Avatar
Brotherhood #1
looking for a pachage deal, on all major gauges Speedo oil temp and pressure volts tach water temp for a veocity taking out the faria.
Mike
Sick Stinger is offline
Old 04-17-2008 | 02:25 PM
Rookie's Avatar
Price and availability on 2 white Gaffrig 2" Oil temp gauges and 2 sendors 1/2" sendors.
5520 9 41.34 $18.00 2" Elec. Oil Temp. WHT (white face Gaffrig Gauge?)
9110 6 19.51 $10.00 Oil Temperature Sender 1/2"
Will these work with each other??
Rookie is offline
Old 04-17-2008 | 07:03 PM
Hi,
Is the black analog 90mph GPS speedo (4020) 3 3/8 size?
If so how much with sending unit?
jez350 is offline
Old 04-18-2008 | 11:29 AM
What color gauges? GPS or regular speedo? How many MPH; 90 or 120? Are you going to need a trim gauge?
Thanks,
Brad
Mike
Old 04-18-2008 | 11:33 AM
Yes these part #'s will work with each other. They are available for the prices shown. 725-5520 $18.00 each, 725-9110 $10 each. Please give us a call or PM if you would like to place an order.
Thanks,
Brad
Old 04-18-2008 | 11:44 AM
Brotherhood #1
Brad yes trim rings silver og gun metal 120 speedo black gauges
-Mike
