got a car question, oil in radiator, no water in block >
Old 04-08-2008 | 09:30 PM
BajaRunner's Avatar
Default got a car question, oil in radiator, no water in block
99 honda accord. Oil in water, made a chocolate shake in the radiator, but no water in the block. Looks like the water blew out as the radiator is low.
Is it an obvious head gasket? Runs good, no smoke. How would I check before tearing apart since its still running good.
Thanks in advance
BajaRunner is offline
BajaRunner's Avatar
just a note, oil is clear and looks good, no water in oil
Old 04-08-2008 | 10:17 PM
If its a automatic its probably the trans cooler in the radiator that leaking
boatnt is offline
Old 04-09-2008 | 07:37 AM
Airpacker's Avatar
Yep, check the trans oil level. Disconnect the cooler lines, plug one and apply 15 or so psi to the other, whatch rad for bubbles. If ok, could very well be a head gasket. Oil is under much higher pressure than coolant. One way transfer.
Airpacker is offline
Old 04-09-2008 | 07:49 AM
Ted G's Avatar
Most likely head gasket, but occasionally I have seen these crack the block between the cyl liners, check very carefully on the deck after cleaning.
www.cbpba.com
Ted G is offline
Old 04-09-2008 | 04:23 PM
Vinny P's Avatar
I hate the winter!!
I am not an expert on Hondas, but some cars have an engine oil cooler in the radiator as well as a trans cooler. If it does have one, it sounds like that may be the problem. I have never seen a head gasket cause oil to get into the water. They can cause water to get into the oil.
Vinny P is offline
Old 04-09-2008 | 04:27 PM
I agree, I have never seen nor heard of a head gasket causing OIL to leak into the Water. The other way around for sure, but not that....
07DominatorSS is offline
Old 04-09-2008 | 04:31 PM
Strawberry shake= tranny cooler in rad shot, chocolate shake=head gasket or head shot. All is true except if your customer puts the wrong oil in the wrong place(as in the rad) of which I have seen before.
Andy is offline
Old 04-09-2008 | 04:36 PM
spazboz's Avatar
I've seen this also. Depends on the design of the cooling system and nature of the failure, sometimes you can get a sort of siphoning effect where the cooling system will draw oil from the motor. VERY common problem with the old 2.8L Chevy they ran in the S-10 series pick-up's.
spazboz is offline
Old 04-09-2008 | 09:38 PM
Been wrenching a long time just go to a good shop have them do a block test 5min..job..head gasket ...with a cracked head..
LastBoatin is offline
