Hitch drop for 2007 Suburban/Yukon >
Old 04-11-2008 | 09:21 PM
Default Hitch drop for 2007 Suburban/Yukon
I have a 2007 3/4 ton Suburban and need to get a new class V ball and mount for it and my new boat/trailer. The receiver is pretty high on the new Suburbans/Yukons and it looks like it will need a hefty drop.
For those of you that have those trucks, what drop are you using? Something like 6-8inches?
synack is offline
Old 04-11-2008 | 09:37 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Check here under products:
http://www.putnamhitch.com/
No way to know exactly what hitch you need for your setup. You will have to measure it and find out.
Sydwayz is offline
Old 04-11-2008 | 11:35 PM
scottc's Avatar
Most trailers are @18" off the ground.
scottc is offline
Old 04-11-2008 | 11:48 PM
tblrklakemo's Avatar
SeaRay Sundancer
You probably wont need any with stock wheels and tires. you will be suprised when you hook it up I think.
I thought for sure I would need some drop on my VMAX but I didnt. Whole rig sits nice-n-level.
tblrklakemo is offline
Old 04-12-2008 | 07:16 AM
BUIZILLA's Avatar
instigator
be sure the insert you get is solid, I just bent the he11 out of a hollow one....
BUIZILLA is offline
Old 04-13-2008 | 04:58 PM
i think 3-4 "
Top Ven is offline
Old 04-14-2008 | 06:58 AM
More like 6-8 he has a 2500 Xl....
Trueser is offline
Old 04-14-2008 | 12:17 PM
buck183's Avatar
I still don't think it will be that much. A 2500 GM truck doesn't need 6-8" of drop. The Suburban won't be any taller. Can't imagine the hitch being that much higher in the frame compared to a truck.
Buck
buck183 is offline
Old 04-14-2008 | 12:23 PM
Registered User
The best way to tell is to level the trailer and measure. Use a bubble level or set the trailer and adjust the tongue jack so the distance between the ground and the trailer frame is the same front & rear. Then measure to the inside of the ball receiver. Add about 2" for tongue weight unless you have auxiliary airbags. If you squat more than 2" you NEED auxiliary airbags.
Check your hitch's capacity. Just because the truck will pull it doesn't mean the people who built it put a hitch on it at that same rated cacacity. I don't know about your specific vehicle but virtually every GM OEM hitch I've ever seen is max 5K lob. capacity. That's not class V.
Chris Sunkin is offline
Old 04-14-2008 | 12:41 PM
Wally's Avatar
Were doomed!
this is the kind i use on my Tahoe....i have the T-bars cranked up a little and run 285 tires and i have no issues with any trailer thus far
http://www.theoempartsstore.com/stor...cat=321&page=1
-Wally
Wally is offline
