Box Anchor size question........... >
Old 04-11-2008 | 10:46 PM
SDH's Avatar
SDH
Default Box Anchor size question...........
Looking at ordering a box anchor for a Donzi 35ZR for a second anchor, mostly for a lunch hook. Those who own one what size anchor do you recommend?
Box Anchor sizes:
Small Box Anchor (collapsed)
$129.95 19 lbs. 22.0" 8.5" 5.0"
Large Box Anchor (collapsed)
$159.95 25 lbs. 25.0" 9.5" 5.5"
Thank you.
SDH is offline
Old 04-12-2008 | 02:51 AM
LakeRacer's Avatar
Charter Member #9/ Moderator
Box Anchor sizes:
Thank you.
Get the larger one for your size boat. You won't regret it at all.
Art
LakeRacer is offline
Old 04-12-2008 | 06:37 AM
OldSchool's Avatar
I have to respectfully disagree with you. I have had the small anchors for my last boat (31 ft. 10K lbs) and my present one(38 ft. 12K lbs.). It works fine!!! It's also very easy to store in the bag that is included.
SDH,
I see that you live in Annapolis. I live in Edgewater. If you would like to stop by and see what the small anchor looks like, PM me and I'll forward my cell#. Hell, you can borrow it if you'd like.
Craig
OldSchool is offline
Old 04-12-2008 | 06:43 AM
Jassman's Avatar
http://www.offshoreonly.com/forums/s...hlight=anchors
I just went through this last week..thread above...I ended up getting a never used small box anchor from Matt, 99Fever27 on the board. It does a great job for my 43 Nortech as my stern anchor...I tried it last night before I put it on the trailer..I bet it would be a great bow anchor but would get the next size up "large". Good Luck. Jeff
Jassman is offline
Old 04-12-2008 | 07:06 AM
Chuck's Avatar
I use the small one even on my 36 Nor-Tech and it holds it well. With one on the bow and one on the stern two small would be fine.
Chuck is offline
Old 04-12-2008 | 07:37 AM
Airpacker's Avatar
I have had 12 boats rafted up on my ONE small box and it held fine. Amazing holding power in sand or mud.
Airpacker is offline
Old 04-12-2008 | 07:48 AM
satisfactionII's Avatar
Does the box anchor hang up on rocks or lake bottom trash easily? If they do how hard is it to get the anchor to release?
satisfactionII is offline
Old 04-12-2008 | 09:30 AM
Wobble's Avatar
SORE MEMBER
They dig really well and a "small" will hold my 29 footer and two other boats tied alongside. Only down side is that they bring up quite a bit of mud and can sometimes be difficult to recover if the bottom is clay. This is Galveston Bay with the tide running and wave action
Wobble is offline
Old 04-12-2008 | 11:19 AM
c_deezy's Avatar
Yes the 'small' isn't really that small, and it works awesome. It's like the Ronco of anchors, set it and forget it!
It does bring up some mud/junk usually but really not any more than what comparable sized spade anchor will pull up. And for the holding power/ease of use it is worth it, just splash it a couple times or hold it low enough under the boat and idle along a little ways and it cleans right off.
I'd like to get baby this year for a stern anchor.
c_deezy is offline
Old 04-12-2008 | 11:34 AM
H20 Toie's Avatar
I use the large one on my 35'
It fits under the back seat no problem
H20 Toie is offline
