factory merc tb modules  #1g22a   v6-14 >
Old 04-13-2008 | 03:38 PM
Default factory merc tb modules #1g22a v6-14
these are fac merc tb IV IGN MODULES,#1G22A V6-14 MODULES,anybody know the advance curves ,redline and total timing on these , i have them on a set of 588'' engines and the dyno guy needs to know more about them
dmaxx3500 is offline
Old 04-13-2008 | 04:15 PM
ok,i figured it out 14degs of advance ,but on a v8 only 8-10 degs,, now for question #2 do i want to run these on a 588'' 9.6 to 1 eng n/a,735lift cam, because of having to start timing at 22degs to get a total of 32degs timing
Old 04-13-2008 | 05:55 PM
Those are probably the best modules for your application. The high initial advance will help with idling around the docks and its not so high that it will cause hot starting issues.
They will be at full advance by 2000-2500rpms.
Griff is offline
Old 04-13-2008 | 06:15 PM
thanks
Old 04-14-2008 | 06:43 AM
They also have no rev limiter built into them like the V8 modules.
shawn is offline
Old 04-14-2008 | 11:52 AM
There is no rev limiter built into TB IV V8 modules either. The rev limters used with TB IV's were only installed on blue engines and were a separate component.
Griff is offline
dmaxx3500
9
04-13-2008 10:04 PM
ghittner
6
09-08-2007 07:09 PM
Canada Jeff
Drives and Lower Units
10
07-26-2007 06:31 AM
boatnuts
0
06-28-2005 12:59 PM
Back4More
0
04-02-2002 11:59 PM
