truck or trailer tire?
Old 04-14-2008 | 12:49 PM
jmackin's Avatar
Default truck or trailer tire?
Larger trailer tires seem hard to come by and expensive. Wouldnt a good 10 ply truck tire be better than a cheap trailer tire for 1/2 the price?
jmackin is offline
Old 04-14-2008 | 12:52 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Absolutely. The Firestone Trans Force (LT) is an excellent trailer tire. I just started switching to them, per recommendation of friends that have been running them for years. I run an E/10 ply 16" tire.
Sydwayz is offline
Old 04-14-2008 | 01:21 PM
Ive been using Chevy HD 2500 takeoffs for years,,,245/85/16 Bridgestones E-rated $300.00 including wheels
Bottomfeeder is offline
Old 04-14-2008 | 01:45 PM
HayJay's Avatar
You'll typically get more miles out of the trailer tires, since the tread pattern is a little less aggressive.
Although, most people's trailers sit more than they roll and the tires will usually dry-rot before they wear out.
HayJay is offline
Old 04-14-2008 | 03:19 PM
7.50 - 16 LT highway rib tread works well and pulls easily. They are 31" tall. These are on 5200 lb axles.
One of my trailers has GoodYears, and they're okay sort of. The other used trailer has no-name ribs, and they have been awesome! Don't leak, wear great, wish I could get more of them.
Chart is offline
Old 04-15-2008 | 01:22 AM
i am told "ST" badge is special trailer and has a stiff sidewall to take the harsh turns' jack knife. i carry 2 spares/2jacks and AAA.
mr.boat is offline
Old 04-15-2008 | 08:11 AM
For smaller tires you are right. But ST's are not offered for 16" wheels, which the heavier axles generally use.
2 spares/2jacks and AAA does sound smart. Do you have trailer service through AAA?
Chart is offline
Old 04-15-2008 | 08:19 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I have AAA as well. They have an "RV+" membership which will service any trailer that you are towing as well. If you break down, they send 2 (tow) trucks and you get free towing for 100 miles.
Sydwayz is offline
Old 04-15-2008 | 09:59 AM
Good info Brian- I have BP/Amoco motorclub and have gotten screwed with a trailer in tow after a breakdown. Might be time for a change....
jafo is offline
Old 04-15-2008 | 10:02 AM
RV plus all the way.
mr.boat is offline
