I need a 2 Circuit Male & Female quick connect Like weatherpac >
Old 04-14-2008 | 02:55 PM
Strip Poker 388's Avatar
Rob
Question I need a 2 Circuit Male & Female quick connect Like weatherpac
I need a electrical 2 wire 10-12 gage quick connect weather proof.I need it for my hatch lift. The weather pack style plugs only goes up the 14gage,
I called Painless and they are the ones that told me 14gage
Any idea's
Rob
Strip Poker 388 is offline
Old 04-14-2008 | 03:29 PM
http://www.delcity.net/
Joe92GT is offline
Old 04-14-2008 | 05:47 PM
Rob
Originally Posted by Joe92GT
This is the only one I saw on there site,said 16-14Ga ,thats to small
http://www.delcity.net/delcity/servl...id=9288&page=1
Old 04-14-2008 | 06:05 PM
I bought my Weather Pack inventory at Waytek. The bodies are the same, you just need the 10-12 pins and blue seals.
http://order.waytekwire.com/IMAGES/M...og/220_033.PDF
BenPerfected is offline
Old 04-14-2008 | 06:12 PM
Wobble's Avatar
SORE MEMBER
My autozone has various combinations of weatherpac in their wiring section
Wobble is offline
Old 04-14-2008 | 09:27 PM
Actually, I just re-read that. PM me your address and I'll mail you some pins. I have the 10-12 gauge pins in my weather pack kit. Delcity does have them too.
Do you have the connectors, if not I'll send a pair.
Joe92GT is offline
Old 04-15-2008 | 07:21 AM
Thunderstruck's Avatar
Rob, I am redoing my hatch lift also. I will probably install ring connectors and bolt the wires together and then heat shrink the connections. IMO, the hatch lift does not need a quick disconnect and the connectors are easily corroded. Food for thought anyway.
Long time cult member.
Thunderstruck is offline
Old 04-15-2008 | 01:23 PM
Rob
Well Ive been taking the motors out every winter,the wire on the lift motor is getting shortIt comes from the factory with a non weather proff conector, so it coroded and Ive been putting a heat shrink conectors since, Also If I have to get to anything down the center of the 2 motors , its makes it nice to remove the lift , It looks like its only around 5.00 for a weather pack conectors.Thanks to Joe92GT
for the part #'s
I bought 2 of these stainless button handle style quick releases.I even polished them. http://www.directindustry.com/prod/j...13-255268.html no more bolts.
at .49 each http://www.delcity.net/delcity/servl...geitem=1&new=y I figure I might as well buy a few different ones and some extra pins for screwing up
I was doing some searching and found this site also www.terminalsupplyco.com pretty big selection.
Ben Ive bought most of my weatherproof conectors from them http://order.waytekwire.com/IMAGES/M...og/220_033.PDF
Old 04-16-2008 | 11:56 AM
Any idea's
Rob
Hey Rob, You didn't remember that I am your connector source. Don't use those weatherpack series stuff. Limited resources from Delphi. I stock some quantities of that series. The Metric Pack series is huge. The 480 series in the sealed version is what you are looking for your application. See the link and page 6 of the pdf. Available up to a 5.0mm (10 gauge) wire. We stock the components (terminals, sealed and secondary locks) and have the 2 cavity male and female also. This is the same connector used in an OEM wire harness we make for a major performance marine manufacturer. Let me know if you still need some sets.
ROTAX454 is offline
Old 04-16-2008 | 06:54 PM
offthefront's Avatar
I used a Accelerator Kit from CP Performance .... had 14 from the box to the Lift ... works good though ...m
offthefront is offline
