Do you need 1000 lbs???
Hardin Marine's new Heavy Duty Drive Plate Assembly rated to 1000 ft./lb of torque!
Introducing Hardin Marine’s new Heavy Duty drive plate rated up to 1000 ft. pounds of torque. Similar to the standard duty drive plate but designed to take the punishment of a high performance engine. These drive plates use a raised center hub allowing better drive plate to spline contact while requiring no flywheel machining. If you are one of the many people with a high performance engine that keeps tearing drive plates apart, then look no further because Hardin Marine has you covered with this new Heavy Duty version transmission drive plate. Click here for more info and to see amazing prices
Please visit our website for more information or to place your order today! www.hardin-marine.com
