2005 Chevy 3500 8.1 DRW
Old 04-16-2008 | 05:27 PM
Question 2005 Chevy 3500 8.1 DRW
I been looking for buying a truck for some time now and have a good deal on a 2005 Chevy duallie CC. Is this a good truck to tow with? My boat and trailer is 11.660lbs dry and the trailer is rated for 15K. I know I have to derate my trailer to make it legal (13K) and I will. I also plan to mount a WD hitch (since Sydaways talked me in to it...). Just looking to see if the 8.1 is a good option. I know mileage wise a diesel is a better option, but I drive about 2000 miles a year so the savings will never offset the purchase price for me. Any experience out there that will like to enlighten my knowledge?
Kims is offline
Old 04-16-2008 | 06:03 PM
jeff32's Avatar
super combo! Not a big difference in mileage per gallon compared to duramax, specially when towing. Plenty of power, that is what you need for your low mileage a year. I have a customer pulling 15000 (up to 20000) each single day of the week and he would not change his trucks for anything else.
jeff32 is offline
Old 04-16-2008 | 06:25 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
What is the gear ratio in the truck? That will make a big difference.
GT4 on the build sticker is 3.73 (check the glovebox)
GT5 on the build sticker is 4.10
Is it the 5 Speed Allison Automatic or the ZF 6 Speed Manual?
Having towed with both the 8.1L and a modern Turbo Diesel, I can tell you that there is quite a noticeable difference in power. That setup should work/tow great for a long time, but a diesel is better. "offshoredrillin" here on OSO has the same truck and he loves it.
Sydwayz is offline
Old 04-16-2008 | 06:46 PM
Not sure about the rear. The plan is to put an OX locker in it, and change the ratio to what is needed could be done in that process. It does have the Allison 5 speed.
Kims is offline
Old 04-16-2008 | 07:32 PM
GO4BROKE's Avatar
I'm sure it already has a locker, why change it?
[img][/img]
GO4BROKE is offline
Old 04-16-2008 | 08:06 PM
BUIZILLA's Avatar
instigator
check the glovebox sticker for G80 and GT5
if it has both, buy it
it'll pull a house down
put 265-75-16E tires on the front, and 235-85-16E on the rear
get a Putnam 15k hitch and the class 6 carrier below
http://www.airsafehitches.com/receiver_hitches.html
then get a big tank from transferflow
http://www.transferflow.com/GM_fuel_tank_systems.html
BUIZILLA is offline
Old 04-16-2008 | 08:26 PM
blownincome's Avatar
great combo we have 2/ 8.1 Avalanches and a 8.1 Suburban as well as 8.1Hds we tow everything from 343 cobalts to 47 Fountains and every thing in between I love the combo if you dont mind the millage Nothing better as a tow package imho.except a Duramax!
blownincome is offline
Old 04-16-2008 | 08:30 PM
Are the aspect ratios the same on the 265s and 235s?? if not wont work on 4X4 wont matter if 2X4
Old 04-16-2008 | 08:46 PM
What does G80 and GT5 stand for? What about 19,5 Alcoas? What tires if 19,5? Interesting hitch, might go with something like that.
Kims is offline
Old 04-16-2008 | 09:10 PM
BUIZILLA's Avatar
instigator
19.5's pull the motor down too hard...
stay with 16's or get some '08 17" takeoff rims/tires
265-75 and 235-85 are virtually the same height
GT5 is 4.10
G80 is posi
BUIZILLA is offline
