Intake manifold water line >
Old 04-17-2008 | 11:45 AM
nordic95's Avatar
Default Intake manifold water line
Does anyone know why there is a 5/8 water hose from the stock merc. water block pump that feeds into the intake manifold just below the thermostat. Is it needed and does it make a difference on a Gen 4 as compared to a Gen 5? Could this hose add or reduce water pressure in the block?or does it just help regulate water temp.?
Thanks Nordic95
nordic95 is offline
Old 04-17-2008 | 11:52 AM
Hey Anthony, been wondering the same myself. From my understanding it's a bypass for when the t-stat hasn't opened yet. Lets water circulate (warm up) until t-stat opens and probably helps regulate psi a little until t-stat opens.
I want to put water psi gauges in my manifolds so I'll be curious to see what others have done. My t-stats are drilled so not so worried about psi build up. A little longer for warm up shouldn't hurt.
handfulz28 is offline
Old 04-17-2008 | 12:04 PM
nordic95's Avatar
My t-stats are drilled also. But my motor guy says I only need this hose on the Gen 4 block, not sure why. It came stock on both motors. Everything seems to be working OK but I would just like to know for my own mental stability.
Anthony
nordic95 is offline
Old 04-17-2008 | 12:05 PM
BY U BOY's Avatar
I was told it primes the pump.
BY U BOY is offline
Old 04-17-2008 | 12:07 PM
nordic95's Avatar
I have the 1-1/2" hose from the t stat to the pump,wouldn't that prime the pump?
nordic95 is offline
Old 04-17-2008 | 12:16 PM
BY U BOY's Avatar
I would guess that the hose from the t stat is above the waterline in the block. And unless the water in the hose leak down it could prime the pump. Just what someone told me. I'm running a crossover on my mark IV so i have never thought about it.
BY U BOY is offline
Old 04-18-2008 | 03:55 PM
nordic95's Avatar
Anyone else have any answers?
Nordic95
nordic95 is offline
Ken N
4
10-02-2008 07:03 PM
Jassman
Active Thunder
20
10-01-2007 08:45 AM
cloudmaster_321
27
05-01-2005 09:45 AM
Zanie
5
03-10-2005 10:58 AM
treatcg
8
01-14-2003 05:36 PM
