454/420 with 496 manifolds???? >
Old 04-21-2008 | 10:06 PM
Default 454/420 with 496 manifolds????
A friend of mine has older 454's built to 420 specs. He currently has the stock merc center riser iron manifolds. Would going to a set of new style 496 aluminum manifolds be worth some HP over the old style iron ones?
MILD THUNDER is offline
Old 04-21-2008 | 10:45 PM
They would flow better and weigh less. Might be worth 1-2mph.
Griff is offline
Old 04-21-2008 | 10:52 PM
Motors were 370's, but now have hot cams, and roller rockers, etc. I bet a free flowing exhaust would really wake them up.
Old 04-21-2008 | 10:55 PM
Talking
YEP !
Regards,
Ray @ Raylar
Raylar is offline
Old 04-22-2008 | 05:45 AM
Would the 496 exhaust bolt up to the old style 454/502 rectangular port heads? I thought there were issue with the bolt pattern. Had to redrill stock CMIs to get them to fit a new 496? Something like that?
Pismo10 is offline
Old 04-22-2008 | 06:38 AM
randy carlson's Avatar
I havent run yet but have fitted my 91 502's with 496 manifolds all lines up nicely, they do exit 1 inch lower
randy carlson is offline
Old 04-22-2008 | 02:43 PM
KAAMA's Avatar
The old Merc 370 is a very good all forged parts engine that came with Crane Gold roller rocker arms.
Also, I believe you are correct about replacing the stock cast iron Merc exhaust with a better free flowing exhaust....especially if you've added a hotter cam. Your engines should respond with some kick...especially in the midrange and maybe 1-2mph on top as Griff said.
KAAMA is offline
Old 04-22-2008 | 06:54 PM
merc is replacing the old aluminum 496 exhaust with iron exhaust because of leaking problems...be careful which you put on..
thedonz is offline
k24u
4
03-05-2007 09:52 AM
jeff32
05-29-2006 08:39 PM
MILD THUNDER
9
09-08-2005 07:36 PM
gripit
18
11-27-2004 03:05 PM
