Portable Boat Shelter
Old 04-22-2008 | 07:11 PM
sleek1's Avatar
Default Portable Boat Shelter
Looking for a 10 X 40 X 12 shelter in tan. Thought I was going to buy one from an internet vendor but the tan is too yellow and he is hard to get a hold of. I figure if I can't talk to him so he can sell me a product, I'll never get a hold of him if I have a warranty issue. Anyone know a good dealer/vendor?
sleek1 is offline
Old 04-22-2008 | 08:07 PM
Registered User
buy direct-
http://www.shelterlogic.com/
Chris Sunkin is offline
Old 04-22-2008 | 10:40 PM
sleek1's Avatar
Thanks Chris but I checked and they don't have the dimensions I need.
sleek1 is offline
Old 04-23-2008 | 06:34 AM
Registered User
Are you looking for a budget solution or something nice? A few years back, I had one made-to-order by a local tent and awning company. It wasn't as expensive as I expected, it was exactly what we needed and the quality was much better.
Noticing you're in Arizona, I'm assuming you're mostly interested in sun shade. If budget is what you're after, why not use two of the WalMart/Sam's Club/Lowe's 10x20's? You can make them taller with standard thin-wall electrical conduit and the replacement tarps are cheap and available.
Old 04-23-2008 | 07:20 AM
t500hps's Avatar
21 and 42 footers
I bought mine through an internet vendor...they had green and white when I got mine.
It was sheltersofamerica.com and they have mine in green or gray (14x42x15). 2.5 years and everything is still good. (you will need to put barrier plastic down on the ground)
t500hps is offline
Old 04-25-2008 | 07:33 PM
sleek1's Avatar
T500HPS- your shelter looks nice. I saw it several months ago while I was researching shelters.
Chris- I'm not trying to go bottom barrel, but was planning on spending somewhere around $2500 delivered. I need quality due to the intense sun here. My problem seems to be lack of tan colored tarps and I can't go higher than 12' so as not to piss off the neighborhood. Most heights go to 15' when you start looking at 40' long shelters.
sleek1 is offline
Old 04-25-2008 | 10:27 PM
SEE IF YOU CAN SHORTEN THE LEG'S TO BRING IT DOWN A FEW FEET ?
MAYBE I DONT KNOW IF IT WILL WORK OR NOT
mikebrls is offline
Old 04-26-2008 | 03:36 PM
Nightlife1970's Avatar
I went to Menards last year and bought two 10 x 20 x 12 round top car enclosures. They are made by ShelterLogic #62667. Cost was less than $700 for the two.
THey have the larger ribs not the 1" ones more like 2 1/2". So they are not cheap.
I then took the two and bolted them back to back, so I now can enter from either side. I used a roll of bosen tape between the two so it does not leak at the joint.
Made it through a winter with no problem. The only thing is it is grey in color.
Nightlife1970 is offline
Old 04-27-2008 | 11:25 AM
Sydwayz's Avatar
Forum Regulator
I owned one for a couple seasons. It was made by Cover-It which now appears to be Shelter Logic. It was erected at a boat storage lot, and I know of 4 owners of that shelter, and last time I checked sometime in 2007 it was still standing after 7 years.
Sydwayz is offline
sleek1
12-20-2007 09:04 PM
Titan
07-16-2004 08:56 PM
CBR
08-04-2002 10:34 PM
LIOPA
06-19-2002 04:39 PM
