View Poll Results: have you ever had engine problem with supercharger?
never had any problem
29
55.77%
had problems more than twice
16
30.77%
will never! EVER! have a blown engine again in my life!
7
13.46%
Voters: 52. You may not vote on this poll
Blown Engine Poll
Old 04-23-2008 | 11:25 AM
jeff32's Avatar
Default Blown Engine Poll
You can have a stock naturally apirated engine and have an engine problem once in your life, wich could be called normal.
This means, you could also have a blown engine (talking mild power here let's say, 400 to 700 hp) and have once in your life an engine problem related to the blower, whatever the brand ( whipple, procharger, vortech ...) wich also could be normal.
What I want to know is, how many of you guys, had blown engines, and ran into engine problem related to the fact that is it supercharged, for 2 times or more?
I'm just trying to see the general reliability of mild power blown engines...
and your comments on that subject!
jeff32 is offline
Old 04-23-2008 | 12:33 PM
Rambunctious's Avatar
I jsut bought a formula with 525sc's
because they are very reliable, blown motors
I plan to maintain them to death and keep them for a very long time.
I am unaware of any 525sc's that had any problems beyond possibly a value train spring issues that a similar cam'd 500hp might have had
seems when someone starts to tweak beyond a reliable scenario to get more power, they then run into problems
take my nitrous injected snowmobile engine for example
( don't ask)
Ramb
Rambunctious is offline
Old 04-23-2008 | 01:03 PM
BBB725's Avatar
It's not marine related but I have the Roush setup on my Ford pickup went from 300hp to 450hp. Currently have 30,000 miles without any issues.
BBB725 is offline
Old 04-23-2008 | 03:27 PM
( don't ask)
Ramb
You won't even have the valve train issues. The cam is only .530/.551 lift and is a flat tappet so you don't have as high of spring pressures.
Griff is offline
Old 04-23-2008 | 03:57 PM
GLH's Avatar
GLH
If you have not blown an engine...
Naturally Aspirated or Blown you either have just started Offshore Boating and are still pulling away from the dock wrapping up your lines or should go for a ride without your wife once and put the coals to it...
GLH is offline
Old 04-23-2008 | 04:23 PM
I've got 575SCi's with about 350 hrs on them
and they've been fabulous
Last boat had HP500's, 1 had a broken lifter,
and valve spring problems at 190 hrs,
after that was taken care of, they ran flawless
til I got rid of it around 425 hrs.
JaayTeee is offline
Old 04-23-2008 | 04:30 PM
lucky strike's Avatar
Most engine problems that I've had were due to the exhaust leaking water into the engines.
lucky strike is offline
Old 04-23-2008 | 04:56 PM
Registered User
I'd rather have 750 hp coming from a warm engine with mild boost that 750 hp coming from a hot N/A engine. You'll have less issues. The bottom end will see the same amount of beating but the vcalve train will have to be more radical. You'll also have to deal with higher idle speeds, fouling, etc. The Achille's heel with blowers is fuel system problems that lean you out and smoke the engine.
Chris Sunkin is offline
Old 04-23-2008 | 08:15 PM
jeff32's Avatar
I'm surprised (happy) that up to now, exactly 50% of people NEVER had any problem with supercharged engines...
honnestly I think it is a pretty impressive number!
Now I have to let the one who had problems the time to answer!
jeff32 is offline
Old 04-23-2008 | 08:19 PM
Biggus's Avatar
Right On!
I've blown up way more motors than I could count, BUT I've never had a motor blow because of the blower. Most problems are valvetrain related and as Lucky Strike mentioned, exhaust leaks can take a motor out real quick.
Kurt
Biggus is offline
