Any Downsides To Downturns ? >
Old 04-27-2008 | 01:20 AM
Nauti By Nature's Avatar
Default Any Downsides To Downturns ?
i'M TRYING TO FIND OUT IF ANYONE HAD THE TROUBLE AND WHAT CAN BE DONE ABOUT WATER SUCKING UP DOWNTURNS FROM VALVE SPRING FAILURE (OR ANY OTHER MAILFUCTIONS FOR THAT MATTER) .
i GOT WATER USING THEM WITH A DRY CMI E-TOP SYSTEM .
THEY REALLY QUIET BOAT AT IDLE AND REDUCED SOME COCKPIT NOISE ON PLANE , i DIDN'T GET ANY POWER LOSSES . BUT SOME MODIFICATION NEEDS TO BE MADE TO PREVENT SUCTION DURING ADVERSE
ENGINE CONDITIONS , OTHERWISE I 'M SCARED TO REPLACE
THEM ( LAW ENFORCEMENT TICKET WAY LESS THEN ENGINE BUILDER TICKET !) CAN ANYONE HELP
THANKS AND BEWARE
Nauti By Nature is offline
Old 04-27-2008 | 06:23 AM
drill 2 small holes in them above water level, they are great for high hp engines without power loss
kgshooty is offline
Old 04-27-2008 | 06:27 AM
nocigarette's Avatar
usually a couple of holes on the top of the elbow will release some of the backpressure in the pipes..It is a exspensive trial and error process but it should help>>>
nocigarette is offline
Old 04-27-2008 | 04:29 PM
Brad Zastrow's Avatar
I run down turns on two boats. One with mild power and the other wild power. Zero issues and no holes drilled.
Brad Zastrow is offline
Old 04-27-2008 | 07:56 PM
THE HOLES WERE THERE AND STILL GOT WATER IN ENGINE
WITH BAD VALVE SPRINGS!
Old 04-27-2008 | 08:05 PM
Brad,
the small holes come drilled from the factory on my gibson pipes . the problem came from defective valve springs
in one of my motors . I belive that without the downturns
no water could come to heads with dry exhust alone .
Howard
Old 04-27-2008 | 08:07 PM
Fountain38SC's Avatar
I was wondering if holes would work on a fountain given the fact the stock exhaust exit with 1/4 of an inch submerged. Nauti how big are the holes in your exhaust and what kind of motors and exhaust are you running?
Fountain38SC is offline
Old 04-28-2008 | 12:41 AM
I think the holes are 1/4 " , my old set up 650 hp 509's w/ b&m 250's , e tops with cmi dry tails into downturns.
Just to be clear the pipes worked great ,BUT when you motor
malfuctions look out ! the water could be coming in your engine like you have thru prop exhust .
Still waiting to hear from gibson about this
Old 04-28-2008 | 06:45 AM
I've never used them but I like the concept. My only issue would be if you don't have a secondary water dump or water pressure guages, how do you know your circulating water properly? I always start the boat, watch for oil pressure and then head to the swim platform to watch for water out the exhaust. I can also get a good feel for when I have an impeller starting to go bad by the time it takes to get water and the volume of water by watching the exhaust.
BGIII is offline
Old 04-28-2008 | 07:32 AM
GLH's Avatar
GLH
Make sure you pressure test your headers it might not be your down turns.
I have never got issues with mine in about 120 Hours.
Attached Thumbnails Any Downsides To Downturns ?-026oso.jpg   Any Downsides To Downturns ?-dsc00655a.jpg   Any Downsides To Downturns ?-dd3.jpg
GLH is offline
