496 mag no oil pressure >
Old 04-28-2008 | 06:41 PM
Default 496 mag no oil pressure
just install a 2006 496 mag with 70hrs ,started it up,but no oil pressure,now what,it shoud not take more than 10-20 sec for pressure right,is this somthing comman?help
apexer is offline
Old 04-28-2008 | 06:47 PM
I would check it with a second mechanical gauge. Could be a bad , or switched connection. Be sure all oil lines are routed correctly.
Darrell.
DMOORE is offline
Old 04-28-2008 | 07:03 PM
pulled the filter its dry,the engine had all oil removed for shipping,does it need to be primed?
apexer is offline
Old 04-28-2008 | 07:19 PM
monstaaa's Avatar
it does. especially now.
more than likely if you didnt run it for maore than 10 or 15 seconds you should be fine.
monstaaa is offline
Old 04-28-2008 | 07:21 PM
how do you prime ?
apexer is offline
Old 04-28-2008 | 07:39 PM
ROB FREEMAN's Avatar
tha thing should have been a clattering with no oil pressure , to prime i believe you pull the distrubutor and use a tool to spin the drive of the oil pump with a drill ?
ROB FREEMAN is offline
Old 04-28-2008 | 08:16 PM
problem solved,removed oil filter,took small piece of rubber hose,and sucked on the filter inlet for 1 min,started her up,there oil pressure,thanks
apexer is offline
Blueabyss
19
09-24-2008 01:05 PM
Harper220
10
05-28-2008 09:13 AM
Biggus
6
05-25-2008 09:03 AM
apexer
2
05-10-2008 08:23 AM
boatfun
3
03-10-2004 01:25 PM
