Removing resin drip??
Yea Tony as stated above use a razor blade to free it up and it should come right off. Make sure to round off the corners of the blade with a piece of 220 (or so) sandpaper, it helps keep the blade from digging in.
08 OPA High Points Champion
Registered User
Go to a body shop supply- they have a little gizmo that turns a single-edge razor blade into a miniature block plane. It's made for taking runs out of paint. They work like a charm. Don't adjust it down too tight or you'll get a gouge. Replace the blade every other pass and you'll get very clean cuts.
If there's no one around, you can mail-order one here- www.tptools.com
Registered User
i'm gonna hafta get one of those . . .
