Eratic Gauges >
Eratic Gauges
Eratic Gauges
Old 04-28-2008 | 10:21 PM
Jim Diesel's Avatar
"Unregistered Gun"
Default Eratic Gauges
I have had my boat out twice since I bought it in February , when I first took it out I noticed that both tachs fluctuated 500 rpm when running and both gas gauges did to. I took it out weekend before last and done the same thing this time the starboard tach was reading 500 rpm higher and it was still bouncing like the port along with the gas gauges. I do have one battery not holding a charge but that shouldnt effect both tachs since they are isolated power wise from each other. Any thoughts, common ground maybe?
Jim Diesel is offline
Old 04-28-2008 | 10:34 PM
Dock Holiday's Avatar
Charter Member #34
Ground
Bad plug wires
Dock Holiday is offline
Old 04-28-2008 | 10:48 PM
Jim Diesel's Avatar
"Unregistered Gun"
Wouldn't bad plug wires cause the engine to miss? When it does this both engines sound in synch with one another and no sign of miss fire?
Old 04-28-2008 | 11:39 PM
You've most likely got a ground short. Check the grounds at the fuel tank sending unit.
Griff is online now
Old 04-29-2008 | 07:42 AM
Charter Member #34
No you do not have to have a miss. A good friend with a 25 Eliminator fought this problem for days and finally changed the plug wires and it went away instantly. He told me about it when I had a similar problema nd I changed the wires and all was good and I did not have a miss at all. Sorry I do not know why or how to explain it. Just a suggestion based on experience.
Old 04-29-2008 | 08:24 AM
Did those erotic gauges cost extra??? Just kidding, the battery will cause some crazy sh*t. Replace that before you go looking for trouble.
kennyo is offline
Old 04-29-2008 | 08:29 AM
Fountain38SC's Avatar
Ditto start with the battery, check the grounds and then go for the plug wires.
Fountain38SC is offline
Old 04-29-2008 | 01:17 PM
Jim Diesel's Avatar
"Unregistered Gun"
Could you explain this, cuz if it was shorted to a positive leg it would blow a fuse or heat up and burn the insulation.
Kenny, bite me but I did get two new battery's today and will try it out this weekend.
Doc, thanks im going to try this using a set of known good wires.
Old 04-29-2008 | 03:02 PM
trips2win's Avatar
I have been chasing the same problem for a couple of seasons checked all grounds cleaned everything i could see finally sent all gauges to livorsi this winter they rebuilt several of them i hope this fixes if not i will try plug wires
trips2win is offline
Old 04-29-2008 | 09:32 PM
J.B. Marshall's Avatar
JB Marshall
Hey Trips I have had the same problem the last two seasons at or around 3500-4000 rpm's. Please let me know if you have corrected your problem with re-worked gauges.
Thanks,
JB
J.B. Marshall is offline
