EFI Harness needed!!
Please, need an EFI wiring harness to fit a 454 Mag (1997)....
got problems in mine with spark/timing control codes showing up & causing idle/dieing problems.
Pls email/msg/call
[email protected]
918-760-1080
Thanks!
Pls email/msg/call
[email protected]
918-760-1080
Thanks!
I have a couple of harness off 1995 502 efi and also 1999 502 efi,which controller do you have,the mefi ecm have delphi numbers on back of box,from that number i can determine what mefi ecm(1-4) you have,I think that is the only difference in the harness,give me a call Dave 410-956-5381
According to Mercruiserparts.com, all 454 & 502 MPI engines used p/n 84-860226A2 efi harness. No change for any ecm change noted
My ecm is a MEFI 1 per Arizona Speed that did my mapping.
I'll call tomorrow!
Thanks.
I'll call tomorrow!
Thanks.
The MEFI1 and MEFI3 (MEFI2 was never used in the 502) wire harness's are different. The MEFI1 had a seperate knock module and different ECM pinouts.
860226A2 is the correct number for a MEFI1 equipped 454 and 502 Mag.
861162T1 is for the MEFI3 ('98 1/2 model year, serial # 0L086001 and above) 454 and 502 Mag.
