Crane Box Question >
Crane Box Question
Crane Box Question
Old 04-30-2008 | 04:14 PM
Default Crane Box Question
Crane HI-6M box and T-Bolt distributor.
I repositioned the rotor to the sensor wheel 35* per the Crane specs. Now the question, when I bring cyl #1 to TDC and drop the distributor in, do I position the shaft/rotor using the original rotor location, or, the "new" 35* rotor location ?
I haven't come across anything in the Crane instructions about this. And I haven't had much luck getting through to the Crane Tech line.
Thanks in advance !
Kidnova is offline
Old 04-30-2008 | 07:26 PM
Bill,
Call 717 838 4767 and talk to Glenn, he spent 22 years at Crane and has a ton of experience with the boxes and a direct line to Jerry the main engineer at Crane.
Chris
cstraub is offline
Old 04-30-2008 | 07:57 PM
I'll give him a call. Thanks !!
Kidnova is offline
Old 04-30-2008 | 07:58 PM
Oops
Kidnova is offline
Old 05-01-2008 | 06:47 AM
Thunderstruck's Avatar
Set the distributor rotor as you would normally do, pointing at #1 with #1 at TDC or whatever you do. Don't compensate for the 35* of the rotor "phasing". The rotor has to point at the appropriate plug wire when that particular pistion is coming up on the firing stroke or the motor can not run, regardless of the rotor "phasing". Also set the timing as you would normally do.
I have the Crane HI-6M's on my modified 500 HPs so call if you have questions.
Tom
337-540-8228
Long time cult member.
Thunderstruck is offline
Old 05-01-2008 | 02:48 PM
Tom
337-540-8228
Thanks Tom !! I'll be in touch.
btw ... I finally got some dyno time for 5/7. Woo Hoo !!
Bill
Kidnova is offline
alecsammy
5
10-21-2008 07:32 AM
Dino
5
06-19-2008 06:12 AM
Kidnova
2
04-21-2008 07:24 PM
OldSchool
09-12-2007 08:27 PM
crmax
43
06-01-2003 04:41 PM
