trim tab problem.....
Old 05-01-2008 | 09:47 AM
Angry trim tab problem.....
okay real quick background.... ordered new tabs, no time to install, friend has shop say's no problem..... shoulda done myself...
heres what happened... i asked them to install 1/2 inch up as i was told, they dint, the tabs are flush with the bottom.... how bad is this?
next there are 4 mounting bolt holes, three along the bottom one on top.... they failed to install all three along the bottom only installed the outside two, how bad is this?
i plan on install the middle bolt but am a little worried about the finish and am curious how bad they screwed up!!
007joe is offline
Old 05-01-2008 | 07:05 PM
monstaaa's Avatar
what type of tabs #1. yes you need all 4 bolts if they are k-planes. as for them being flush with the bottom, not good. can create a multitude of negative issues. porpousing, hook, grabing water, and so on.
what part of staten island?
monstaaa is offline
Old 05-01-2008 | 07:09 PM
they're eddie marine tabs.... they're e-planes, they dint put the center bolt in cause of a stringer in the way... now i dunno what to do .... i'm in willowbrook
007joe is offline
Old 05-01-2008 | 09:44 PM
Take them off before the 5200 sets up! Fill the old holes with 5200, move the tabs up 1/2", and put a lag screw in the center one with the stringer in the way.
jdub is offline
Old 05-02-2008 | 10:28 AM
jhiguy377's Avatar
like jdub said
jhiguy377 is offline
Old 05-03-2008 | 06:38 PM
monstaaa's Avatar
where are the tabs mounted in reference to the outer most chine?
and i have another location in staten island. you may be able to go there for some help. send me a private message and i ll give you some more info.
monstaaa is offline
Old 05-03-2008 | 07:05 PM
007joe is offline
Old 05-03-2008 | 08:30 PM
Velocity Vector's Avatar
Crazy Energy
Jesus!!
Velocity Vector is offline
Old 05-04-2008 | 09:08 AM
Originally Posted by Velocity Vector
Jesus!!
THAT BAD HUH? I GUESS I GOT TO GET TO MOVING THEM... IF YOU WANT SOMETHING DONE RIGHT YOU GOTTA DO IT YOURSELF!!
007joe is offline
Old 05-04-2008 | 09:54 AM
Crazy Energy
10-4 Since you already have holes in it you may want to go up 1" instead of 1/2" to get away from the other holes a bit more.
My plates came in yesterday, changing out to 28" plates.
