Trailer Tires?
Old 05-06-2008 | 06:37 PM
camptappakeg69's Avatar
Default Trailer Tires?
Time for some new sneakers for the manning, what does everyone one use?
Radials or Bias?
What brands are good and what are bad?
camptappakeg69 is offline
Old 05-06-2008 | 06:47 PM
baja bailey's Avatar
I have had real good luck with Goodyear trailer tires, I think they are called marathon ?....
baja bailey is offline
Old 05-06-2008 | 06:52 PM
Registered User
Marathon is probably the all-around best choice. You can get commercial trailer tires in 16 but they're pretty expensive and not really worth it unless you're doing regular long-distance towing ona very large boat.
You need ST-rated tires unless you like wander & sway.
Chris Sunkin is offline
Old 05-06-2008 | 07:13 PM
Chris, ST OR LT? most of the myco's I see have LT
bgchuby01 is offline
Old 05-06-2008 | 07:56 PM
Comanche3Six's Avatar
Here is what Myco put on my trailer.
Goodyear Trailer Tire, LT235-85R-16, Radial Load Range-E
Comanche3Six is offline
Old 05-06-2008 | 08:04 PM
that is the standard tire for a 38 to 40 foot boat on a myco. great tire with few failures
Old 05-06-2008 | 09:09 PM
The Menace's Avatar
Do not use Bridgestone or Firestone. (same company)
The Menace is offline
Old 05-06-2008 | 09:53 PM
Registered User
ST is "special trailer". They have a much stiffer sidewall. LT is "light truck".
Old 05-07-2008 | 01:10 AM
most of the ones I see are LT
Old 05-07-2008 | 06:26 AM
From: A tree somewhere in the woods in Clarcona Fl.
I've used 187 series Bridgestone (commercial L/T) tires on a couple of trailers and had excellent luck with them with no failures,,,,but they are kind of pricey.
Slick02 is offline
